Home > General Chat > Pre verto clutch spec
Just working out which clutch combination to use in the metro build. I've got an ultralight flywheel already with a double grey cover and paddle plate. Also have a standard turbo plate.
The thoughts are to use the paddle plate but with a single grey cover? Or do you think i could get away with a standard turbo plate as well?
Not going to be a road car
IMO rob ditch the double grey its not needed, fit a single grey and use a ALCON 5 fingerd plate then use 3 straps per lug and machine each lug post down 0.030" on the back platej ....... job done! it will work great and and wont let you down done dozens like that and not a problem to date
Edited by BENROSS on 17th Mar, 2015.
