Page: |
Home > Beginners Tech > 16V Conversion plate seal | |||||||
67 Posts Member #: 8956 Advanced Member Algarve/Portugal |
24th Feb, 2015 at 09:59:18pm
Hi, what do you guys say for using this type off seal for the bottom plate of my 16V conversion?
65 Posts Member #: 9646 Advanced Member Bristol England |
27th Feb, 2015 at 10:28:19pm
I made all my plates to use the standard size front crank seal, I made the plates with clearance holes for the cams, then fitted rings with seals in to the cams, marked out and drilled n tapped to attach. I made stub shafts to extend the cams and to mount the pulleys, the seals run on those. The plates are made from 10mm aluminium gauge plate. I drilled and tapped the original cam to take the bolt as pictured.
Edited by Nick king on 27th Feb, 2015. |
27th Feb, 2015 at 11:54:44pm
I'm using the std mini front seal for head and crank also, for the top I use a 10mm alloy also.
Edited by R.Rodrigues on 28th Feb, 2015. |
Page: |
