Page: |
Home > Technical Chat > Pitot tube + 37mm Restrictor? | |||||||
5 Posts Member #: 9954 Junior Member |
23rd Feb, 2015 at 04:30:58pm
Hi - I'm designing a new better flowing plenum without that brass restrictor ring. This has been explained in detail else where on this forum regarding Pitot tube and the 37mm restrictor plate. My question is - using the Pitot tube will I need to blank off the two holes that feed the fuel chamber that allows a higher pressure forcing fuel out the needle valve under boost pressure to stop it weakening out (see pic). The balance tube should be rerouted from fuel chamber out too Pitot tube - correct?? The 37mm restrictor is easier to do but as Im trying to get maximum air flow through the carbs surely it will be a counterproductive to air flow?
23rd Feb, 2015 at 10:08:10pm
My suggestion (from someone who spent a few years dicking about with restrictors) is to replicate what is inside the metro plenum...
Page: |
