Home > A-Series EFI / Injection > MS Qustion about changeing settings AFR-Lambda and sensor inputs in logs
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
so ive beein fiddleing and not had much luck finding how to change from ARF to Lambda in MS i want to change as ill be changeing fuel type in a few weeks
also id like to rename the generic sensor inputs 1 and 2 that im useing for oil pressure and oil temp
what tuning / log software you using?
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
meggalog viewer/tuner studio megga squirt 3x
Edited by Turbo This.. on 18th Feb, 2015.
In TunerStudio, go file, project, project properties and change the setting from "wideband (default)" to lambda.
It will also need changing in your msq but if you have the paid for version of TunerStudio, when you restart it will ask if you want the controller settings (msq) to be changed to match the project settings.
For the gauges, again, if you have the paid for version you can redesign the display to look however you want.
I think with the "lite" version you would probably have to alter some of the text in the "ini" file.
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
ringht thanks rod ive got the afr sorted and the dashbord changed
just the sensor renameing in megalog vewer but that i can live with if to hard
Not sure Josh, I thought MLV just picked up the new titles from the TS project file and/or the ECU msq.
Have you tried re-booting both TS and the ECU (just turn the ignition off and on again for the ECU).
Otherwise there is a menu in MLV, "options, field naming (ECU)" where you can force it to MS3 but mine is just set at default and works fine.
Graham T
Member #: 1106
Hungerford, Berks
I normally change the “labels” of the channels for datalogging in the mainController.ini file.
Find the TunerStudioProjects folder (for Win8.1 it is in the documents folder), drill down into your project folder>projectCfg
Open the MainController.ini (or the actual ini file that is being used by the project) in a text editor and scroll right to the bottom.
The last section of the ini file is [Datalog]
Find the entry that corresponds to the channel you need to change the label of.
Example for AFR1:
[Datalog]
; Channel Label Type Format
entry = time, "Time", float, "%.3f"
entry = seconds, "SecL", int, "%d"
entry = rpm, "RPM", int, "%d"
entry = map, "MAP", float, "%.1f"
#if NARROW_BAND_EGO
entry = egoVoltage, "O2", float, "%.3f"
#elif LAMBDA
entry = lambda1, "Lambda", float, "%.3f"
#else
entry = afr1, "AFR", float, "%.2f"
#endif
Now modify the data in the third column (Label) to what you wish to see in MegaLogViewer.
entry = afr1, "Outer Cylinder AFR", float, "%.2f"
Save and close, then restart TunerStudio.
Edited by Graham T on 20th Feb, 2015.
’77 Clubman build thread
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=618189
Siamese 5 port EFI testing
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=611675
