Page: |
Home > General Chat > Bandsaws and bench sanders. | |||||||
16th Feb, 2015 at 08:14:33pm
hey folks,
16th Feb, 2015 at 09:10:28pm
Depends on your standards i guess, ive got two clarke ones and they work ok but if you lean on them too hard they stall. Dont even bother with the disc imo, they are too small. The linishing belt part works ok tho.
16th Feb, 2015 at 11:26:11pm
I have got the smaller Clarke horizontal, CTS45 rings a bell, it's fine for anything I have wanted to do, it easily cuts tube, the biggest I have asked of it was 40mm solid round bar, or 50x100x5 box, both no problem. Around £180 new but lots second hand as well. Having a quick look it's 370w so probably the same as you are looking at.
Edited by Tom Fenton on 16th Feb, 2015.
![]() 696 Posts Member #: 10034 Post Whore Birmingham |
17th Feb, 2015 at 12:18:39am
Bough a sliding mitre saw purely for wood, but it came with a multipurpose blade, so I tested it on some stainless /aluminium tube. It worded great - clean, perfectly square/angled cuts and ridiculously quick. 2" X 8" is easy enough; If 3" is occasional you could take a cut from both sides and still get nice enough cuts.
Edited by PhilR on 17th Feb, 2015. |
17th Feb, 2015 at 06:35:21am
I've used circular saws with carbide tipped blades. Great on ally but stainless would dull the blade after a short while. They work better on section than solid too. |
![]() 6748 Posts Member #: 828 Post Whore uranus |
17th Feb, 2015 at 07:42:27am
phil what's the difference between those two to warant the 50 quid extra? i have been looking at the rage3 for a while .
Edited by robert on 17th Feb, 2015. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
336 Posts Member #: 9941 Senior Member Derby |
17th Feb, 2015 at 07:49:24am
Buy the evolution saw there brilliant I'd also say buy the bigger one of the two I use a 110v one at work cutting unistrut all day long. But stainless does take the edge of the blade! |
17th Feb, 2015 at 07:49:26am
17th Feb, 2015 at 09:16:45am
cheers for that Tom, I was looking at the Draper version of that saw, good to know it will handle the stuff.
17th Feb, 2015 at 12:50:12pm
Good point about cutting stainless steel - I had a quick look and having trouble finding stainless blades. The multipurpose blade cuts mild steel sections with no problems though.
On 17th Feb, 2015 robert said:
phil what's the difference between those two to warant the 50 quid extra? i have been looking at the rage3 for a while . oops i spotted it . the clue is in the name lol ,210mm versus 255mm. which is the one you have phil? Bought the smaller 210mm one for £100. At the time, the 255mm was £200 so couldn't justify the extra cost. |
17th Feb, 2015 at 01:26:49pm
do you get a decent square cut from it? the clark is lloking like a winner for me at the moment, especially If I can pick a 2nd hand one up.
On 16th Feb, 2015 Tom Fenton said:
I have got the smaller Clarke horizontal, CTS45 rings a bell, it's fine for anything I have wanted to do, it easily cuts tube, the biggest I have asked of it was 40mm solid round bar, or 50x100x5 box, both no problem. Around £180 new but lots second hand as well. Having a quick look it's 370w so probably the same as you are looking at. Interested in which linisher you have as that's next on my hit list. On 28th Aug, 2011 Kean said:
17th Feb, 2015 at 01:30:49pm
Yes, its all fully adjustable, it will wander off on stuff thats easy to cut, say 2.5" thin alloy pipe, due to it falling through too quickly, easy enough to sort though just by slowly lowering it through the cut by hand.
17th Feb, 2015 at 01:49:58pm
Re. The linisher. One of mine had a nacked motor bearing and that made it gutless. Couple of quid on some eBay bearings fixed it. |
![]() 5988 Posts Member #: 2024 Formally Retired Rural Suffolk |
17th Feb, 2015 at 02:40:34pm
Clarke CBS45 (I think Tom was one letter out).
Edited by Rod S on 17th Feb, 2015. Schrödinger's cat - so which one am I ??? |
![]() 489 Posts Member #: 9159 Senior Member Devon |
17th Feb, 2015 at 07:51:07pm
25th Feb, 2015 at 07:36:37pm
I have been using mine over the last couple of days so here's some further comments if you do get one.
25th Feb, 2015 at 07:59:17pm
funnily enough, last friday a machinmart voucher came through... so I got a clarke one,
Page: |
