Page: |
Home > Wanted > 240volt low rpm motors,1hp ish | |||||||
6965 Posts Member #: 507 Fastest A Series Mini in the World leeds/wakefield. |
15th Feb, 2015 at 04:31:58pm
gents, I'm looking for one at 100-150 rpm max where would one buy such a thing and another even lower rpm,
15th Feb, 2015 at 04:40:15pm
Search for gearmotors or conveyor motor or conveyor drive.
Edited by TurboDave16V on 15th Feb, 2015. On 17th Nov, 2014 Tom Fenton said:
8297 Posts Member #: 408 Turbo Love Palace Fool Aylesbury |
15th Feb, 2015 at 04:59:00pm
You'll probably have to go down the inverter route for something that low in rpm. Or use belts and pulleys to gear it down. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
15th Feb, 2015 at 05:04:45pm
get your bids in...
15th Feb, 2015 at 05:06:56pm
http://www.ebay.co.uk/itm/Single-Phase-1-2...=item1c352b0a6e
15th Feb, 2015 at 05:08:54pm
15th Feb, 2015 at 05:29:42pm
I am going to make an auto rim polisher,
15th Feb, 2015 at 08:29:51pm
Parvalux make a range of motor gearbox combinations. This is just one example http://uk.rs-online.com/web/p/ac-geared-motors/0717893/ |
15th Feb, 2015 at 09:44:13pm
Yeah, I'd totally recommend using a gearbox to get to anything in a 100-300rpm window, then using a chain or vee belt to get the final ratio adjusted to where you think you want to be, as you will likely want to play with the speed at some point.
On 15th Feb, 2015 fastcarl said:
I am going to make an auto rim polisher, so I need one motor to rotate the rim, one to drive the polish mop[that's the easy bit] and I need a third to rig up some kind of rotating yoke to traverse the polish mop. simply really. carl On 17th Nov, 2014 Tom Fenton said:
Page: |
