Home > Beginners Tech > quick brake question
Rammie2000
Member #: 10190
belgium
Hi . Can't find it back while im sure i read it here. If i turn down 8.4 disk's to fit a 7.5 caliper should i keep it as big as posible? It would make a smaller friction surface turned down to the same size as 7.5 because the centre is bigger. What would the pro sides be what would the downsides be.? I would use 2 piston 7.5 calipers.
Chalkie
Member #: 9764
Northamptonshire.
Off memory you turn down 8.4 disc for the 7.9 disc but you can't do it for 7.5
R.Rodrigues
Member #: 8956
Algarve/Portugal
Minispares callipers use metro disc turn down to 7.5"
http://www.minispares.com/product/Classic/...ack%20to%20shop
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
id guess so long as the contact area is on the rotor its fine and turn any metiral away thats not where the pad will run to save weight
Rammie2000
Member #: 10190
belgium
O its just for the traveller. I found some calipers and was thinking what to do with all them brand new and nearly new 8.4 disqs. ... yet if it works well i would like and give it a try to drill them to. Then what is the reasen that the 7.5 has a smaller centre?
