Home > General Chat > Did I go abit overkill?
Chalkie
Member #: 9764
Northamptonshire.
These are pictures of my Bracing.
Thanks
D4VE
Member #: 10749
lowestoft suffolk
Perfect climbing frame *smiley*
Nothing gets past Dave lol
jonny f
Member #: 9894
Dorking
better safe than sorry!
Chalkie
Member #: 9764
Northamptonshire.
its not been fun to get in and out of to weld it today.
Callum
Member #: 10396
Stoke-on-Trent
You might not have any issues as it's not all coming out at once but you could of done with some diagonal bracing in there really, rectangles can fold in on themselves whereas triangles can't ...or a lot more force is required to do so
PhilR
Member #: 10034
Birmingham
Looking good to me, but definitely triangulate it - will be MUCH more rigid.
Someone "helped out" by doing some welding on my wife's Mini shell. Pretty much the same job you're about to tackle, but with no bracing; Then a few days after while still in the garage the windscreen just shattered. I'm not looking forward to putting it right *frown*
well are you a midget ....lol will be ok if you are and it looks kinda solid.
Chalkie
Member #: 9764
Northamptonshire.
Yeah the cars sat on its side now ready to sort this lot out any tips?
Into this bit
This was my first weld patch wise on the mini
Edited by Chalkie on 5th Feb, 2015.
Chalkie
Member #: 9764
Northamptonshire.
So is this enough bracing now? gotta add one or 2 more but is this good enough?
doors still fit same as they did day i brought the car odd either side haha gaps still measure the same
PhilR
Member #: 10034
Birmingham
Looking good.
When you cut the floor out, the panel in the footwell will be able to flap around on the lower edge. The edge is fine to move around a bit as you'll need to a bit of give to weld it to the floor, but you don't want the lower subframe mounts to move when you pull the panel the panels together. Tack a long horizontal section, butted up against the panel, across the mounts, ending at inner wings.
Chalkie
Member #: 9764
Northamptonshire.
Phil even on half floors? Okay I'll weld a bit down to the toe board awell got enough bracing left
PhilR
Member #: 10034
Birmingham
Or.... leave the subframe in. Things that you don't want to move are the subframe mounts and door mounts.
From what you've shown so far, I think you're not going to have a problem. Good work :)
Chalkie
Member #: 9764
Northamptonshire.
Okay I'll strip the front subfrane down abit gotta do same with the rear anyways so I can aline the heel board properly I'll drop a bit down onto the toe board anyway as extra thanks Phil Been a great help
jonny f
Member #: 9894
Dorking
There's a shot I saw recently from Owens fabrication of a shell with no floor in it that had less than half the bracing you have. I'd imagine it's easily enough.
D4VE
Member #: 10749
lowestoft suffolk
Yeah the pics of mine with the complete floor out didnt have anywhere near that much bracing so im sure ur safe
Here it is- http://s1368.photobucket.com/user/d4ve87/m...html?sort=3&o=8
probably nowhere near enough but it must of been fine
Edited by D4VE on 7th Feb, 2015.
Chalkie
Member #: 9764
Northamptonshire.
Okay im happy with mine I'm only doing half floors aswell thanks guys
