Page: |
Home > General Chat > OT - Which exhaust material | |||||||
![]() 293 Posts Member #: 10010 Senior Member Northants |
2nd Feb, 2015 at 08:41:33pm
Hi Everyone,
![]() 696 Posts Member #: 10034 Post Whore Birmingham |
2nd Feb, 2015 at 10:17:18pm
Are the cracks radial or along the length? inside or outside of bend? Are they on the ERW seams? I assume you did the bends yourselves? How rigid are the fixings? Edited by PhilR on 2nd Feb, 2015. |
3rd Feb, 2015 at 12:15:39am
304 stainless should take care of all your issues... Just purge or solarflux it when welding. On 17th Nov, 2014 Tom Fenton said:
3rd Feb, 2015 at 10:33:24am
It cracked as shown below, on the centre line of the bend, both top and bottom.
3rd Feb, 2015 at 11:03:20am
is the exhaust able to flex as it heats up? Yes i moved to the darkside |
3rd Feb, 2015 at 11:26:54am
How well bracketed is it? Looks a lot hanging out from the picture.
3rd Feb, 2015 at 05:12:27pm
In the picture above you can just about see a sheet metal support where the square flanges are (Near the lambda sensor),
3rd Feb, 2015 at 05:49:47pm
Too far along in my opinion. Wants something near the second bend from the head that supports it. Obviously as you have alluded to it needs to support it whilst not restricting expansion.
3rd Feb, 2015 at 08:23:35pm
That has more than likely cracked where the tube has been seam welded. It is always on the edge of the bend rather than inside or outside. If you look inside the bend, use probably see a small 'pip' along the bend where it has been welded.
![]() 8215 Posts Member #: 90 Post Whore Somewhere around Swindon |
4th Feb, 2015 at 10:35:16am
On 3rd Feb, 2015 jakejakejake1 said:
It cracked as shown below, on the centre line of the bend, both top and bottom. The bends were mandrel bends bought in from this place http://www.thebendshop.co.uk/Mandrel.html Crystal Sound Audio said:
4th Feb, 2015 at 07:37:11pm
We are currently using 16 gauge/1.6mm.
Edited by jakejakejake1 on 4th Feb, 2015. |
4th Feb, 2015 at 09:58:46pm
Do you know what grade the mild steel was? Did you notice any scoring or gouges left from the bending die? If the die was a touch too small, it may have left deep enough marks perfect for starting a crack, just where you've highlighted, on both sides.
Edited by PhilR on 4th Feb, 2015. |
![]() 539 Posts Member #: 6807 Post Whore York |
4th Feb, 2015 at 10:20:21pm
Try this place, they'll make whatever angle you're after for no extra cost
On 4th Feb, 2015 jakejakejake1 said:
We are currently using 16 gauge/1.6mm. Any ideas of where to get 304 bends from at a reasonable price? We also thought it might be due to the seam weld, but it cracked on the opposite side to the weld as well as on the side of the weld. We got an infra red temp gun on it today while running and it went off the scale hot, glowing red (scale ends at 650C). Will this be a problem for 304? Cheers Edit: tube diameter is 1.75"/44.5mm |
4th Feb, 2015 at 10:43:16pm
http://www.jpexhausts.co.uk/product_listin...p?id=37&t=Bends
5th Feb, 2015 at 08:20:14pm
Profusion have a good reputation and are a massive supplier of exhaust parts.
Page: |
