Page: |
Home > Beginners Tech > can you identify this unit | |||||||
18 Posts Member #: 10957 Member sussex |
1st Feb, 2015 at 08:58:51pm
i have just brought a fuel pressure reg off of a metro turbo. it came bolted to a bracket with another unit bolted to it.
3004 Posts Member #: 2500 Post Whore Buckinghamshire |
1st Feb, 2015 at 09:07:01pm
That is the solenoid operated valve used by the Metro in connection with the reduction in boost below 4000rpm.
1st Feb, 2015 at 09:16:56pm
arr so its a bleed of valve for actuator |
1st Feb, 2015 at 10:02:55pm
On 1st Feb, 2015 braziers said:
arr so its a bleed of valve for actuator Fastest 998 mini in the world? 13.05 1/4 mile 106mph
270 Posts Member #: 69 Senior Member Coventry |
4th Feb, 2015 at 09:05:52pm
does it have the black air stone thingy on it still?
Page: |
