Page: |
Home > General Chat > Valve seats | |||||||
![]() 263 Posts Member #: 8923 Senior Member North Wales |
1st Feb, 2015 at 12:47:53am
Hi All,
![]() 4629 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
1st Feb, 2015 at 09:51:01am
They're usually pretty obvious to see. If you take the exhaust valves out and look into the throat you can usually see where the insert is fitted. They're about 8mm deep and there's often quite a step/lip as they aren't blended in at all from the factory. They were fitted from around 1989 onwards.
510 Posts Member #: 1592 Smart Guy! mainland europe near ze germans |
1st Feb, 2015 at 09:52:42am
take out valve look for seat insert. imho only foolproof way . there was thing about rivets indicating seat type but given the consistency of BL i'd just check That sir, is not rust, it is the progressive mass reduction system
![]() 696 Posts Member #: 10034 Post Whore Birmingham |
1st Feb, 2015 at 01:51:54pm
If you have the head in front of you with the valves out, note that only the exhausts would have hardened seats (on cast iron heads).
Page: |
