Page: |
Home > Wanted > wide(ish) wheel arches | |||||||
1142 Posts Member #: 10165 Post Whore Stansted, Essex |
26th Jan, 2015 at 06:31:23pm
Chaps,
7265 Posts Member #: 1268 The Boom Boom speaker Police! Essex |
26th Jan, 2015 at 09:15:07pm
I suggest you get your wheels first before fitting arches. In the 13's at last!.. Just |
26th Jan, 2015 at 10:44:37pm
Indeed.. Realistically it's gonna be the 7's.. I'm under the impression that all the arches I've listed above will be ok with the 7's (so I've been told) with the possibility of a bit of fettling?
56 Posts Member #: 5200 Advanced Member Bath, Somerset |
27th Jan, 2015 at 09:10:25am
I have some of these http://absmotorsport.co.uk/index.php/wa07-...il#.VMdUN2SsUpA
27th Jan, 2015 at 11:44:14am
Cheers Jeff.. I'll have a measure up.
6729 Posts Member #: 618 Post Whore Glasgow |
27th Jan, 2015 at 12:08:05pm
just make sure they will work with tubbed rear arches Dave |
27th Jan, 2015 at 01:16:10pm
Not sure, £40 sound fair? Not sure on tubbed arches though, as the return lip buts up against the body to allow for fixings. I don't think there's a concealed fixings-type of arch extension that will work with a tubbed car, but can't be sure. Edited by Jeff R on 27th Jan, 2015. |
27th Jan, 2015 at 01:23:44pm
Yes Rob good point... I must investigate that. Just rang a buddy and he reckons group seven smooths would be my best bet with tubbed arches...
27th Jan, 2015 at 02:06:55pm
I'm running GP5euros on mine but it is tight at the top of the arch, bearing in mind it is mounted on the return lip |
27th Jan, 2015 at 03:22:18pm
Ok good info there.. Never straightforward is it! |
78 Posts Member #: 2322 Advanced Member rednal birmingham |
19th Feb, 2015 at 07:08:02pm
hi I have a brand new set of group 7's in black gel coat, they have been trimmed, but undrilled, I got them from Huddersfield spares, I've fitted a set of miglias as ive gone the racer look Edited by jonny on 19th Feb, 2015. YOU CANT POLISH A TURD, BUT, YOU CAN ROLL IT IN GLITTER!!!! |
Page: |
