Home > 998cc > What Cam for 998 with SC12
1275gtsport
Member #: 11035
New Brunswick Canada
Ok I have been planning this for many years and gathering parts along the way. health reasons put on hold several times. have lost all the notes I had made.
So this is the basic's 998 being bored 20 over using dished piston's to keep ratio down.
going to be using the nissan dizzy
standard crank
have a turbo metro carb. making the system blow thru as I am in Canada and the steering wheel is on the left! so the S/C will be out front. not sure exactly where the alternator will be going.
Need to come up with a cam. what do I order?
The car will be used for autocross/auto slalom/ solo racing (depends on where you live as what they call it)
Standard tranny no funding left to upgrade at this time.
Also not sure if this is the right term but do I need a blow off valve? would one be built into the S/C? and do I need an intercooler?
Sorry if this post is a little disorganized still dealing with Health issues and sometimes the meds have me confused.
MG Metro, 266 etc would all be good. I have a 274 in my 1293 suck through sc12.
You will need a blow of valve as it will carry on blowing against the butterfly when you let off the throttle. Maybe look at one from a bini m45 setup or one of the 'compressor' Mercedes.
I use the re13t at 112lca which seems to work well and pull to 7500 easy.
PhilR
Member #: 10034
Birmingham
If you're giving it any abuse, you should fit a cross pin diff as the standard one WILL fail pretty quickly. The rest of the gearbox should be fine if it's in reasonable health.
I've seen a front mounted BINI supercharger and it looked tidy. They used a physically smaller alternator and a late model MPI head that has a bracket to mount the alternator higher. The oil filter may need to be relocated. Both jobs should be relatively easy to fabricate new mounting hardware.
Edited by PhilR on 13th Jan, 2015.
slater
Member #: 1291
Suffolk / Birmingham
Id certainly run an inter cooler, that's half the benefit for running blow through
1275gtsport
Member #: 11035
I should also mention we have a gt15 Longman head. will get the intercooler.
and gr4h4m I have no idea what you said. (the medicated confusion)
hazpalmer
Member #: 9038
Carlisle, Cumbria
The RE13T is a type of cam shaft made by Graham Russell over in Australia, made for turbo engines
He does a supercharged version that is ground at 112lca. You can get them from Keith calver in the uk
mattsmadmini
Member #: 9965
Sydney, Australia!
He also does an RE83T, and im sure if you asked nicely he'd grind one of his new profiles in turbo/super form...
“A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.” - Jeremy Clarkson
