Home > For Sale > mpi fuel tank
Hotson
Member #: 10226
Grantham, east midlands
Hi guys, got an mpi fuel tank for sale just taken out of my old turbo mini.
Everything works, was told the pump was noisy when I brought the tank but it works fine and sounded just like a fuel pump to me.
Any way looking for £50 collected from Grantham or can take to Bingley with me.
Hotson
Member #: 10226
Open to offers
TurboTom
Member #: 7936
DK-8450 Hammel. Denmark
Pm`ed
If i have more toys than you when i die, I WIN
Hotson
Member #: 10226
Still for sale. Will be at Bingley on Sunday.
Hi Buddy,
Sorry to be the bearer of bad news but unless it's had the pump swapped that is an SPI tank. It's got the long filler neck and no sound deadening on the exterior.
your right J
dazibee
Member #: 1356
TRURO, CORNWALL
Its nearly midnight, ive just been out to the garage in the rain, spiderman onesie donned to make sure my mpI tank is not an spi. Mine looks like that one but has a square piece of sound deadening on the inside. Is mine an mpi then?
Edited by dazibee on 23rd Jan, 2015.
Is the filler neck stubby??
dazibee
Member #: 1356
TRURO, CORNWALL
It dont stick out as far as the old carb one
Sounds like mpi then.
Rammie2000
Member #: 10190
belgium
While at it...
This is spi right? Is it suitable for a 1293 turbo build gt1752 ? Aiming to run 12 to 15 psi...
Hotson
Member #: 10226
Hi John, the neck it's not as long as a carb model (not knowing about neck lengths) just thought this was odd when swapped the tanks. And it looks as though it had some stuff glued to the front of it where the strap comes over the tank?
It worked well in my 998 turbo. Was sold it to me as an mpi as apparently that's what it came out off.
Strange.
Probably best to whip the pump out and put the part no into google. That will clear it up.
Spi rammie. Suitable up to 10psi
Just update the pump if you want more.
Andy is right only sure fire way is to pull the pump but my money would be on spi from its external appearance
Hotson
Member #: 10226
😡 bugger, just not got the time to mess with it, surplus to requirements now. But if somebody needs to know for definite then I'll pull the pump out. Thanks though guys.
