Page: |
Home > Beginners Tech > hiff 44 leak | |||||||
15 Posts Member #: 10908 Member norfolk |
4th Dec, 2014 at 02:21:12pm
hi can anyone help please, i have recently bought a hif44 turbo carb, fitted it turn ignition on and fuel is being pumped into the plenium chamber and filling it up, is this just a case of a seal leaking?
882 Posts Member #: 9774 Post Whore Buckinghamshire |
4th Dec, 2014 at 02:31:24pm
Sounds like you've got the fuel feed on the wrong barb. is there two(three?) on that side of the carb? http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
4th Dec, 2014 at 02:43:33pm
two next to each other at bottom and one further up if that makes sense |
4th Dec, 2014 at 02:45:31pm
i thought left one fuel in then the one next to it ive blanked of and one above linked to bance pipe |
9502 Posts Member #: 1023 Post Whore Doncaster, South Yorkshire |
4th Dec, 2014 at 04:20:12pm
Could be a whole lot of things from too much fuel pressure, incorrectly set float hight, stuck jet (open) to just plumbed up wrong
Yes i moved to the darkside
7265 Posts Member #: 1268 The Boom Boom speaker Police! Essex |
4th Dec, 2014 at 04:31:32pm
Fuel feed piped into the plenum?
In the 13's at last!.. Just |
4th Dec, 2014 at 04:38:32pm
lol i am silly but not that silly, plenum pipe going to regulator.
4th Dec, 2014 at 04:46:37pm
Which port on the regulator? In the 13's at last!.. Just |
3673 Posts Member #: 9300 Post Whore Quarry Bonk |
4th Dec, 2014 at 05:32:06pm
Check that the bores arent full of fuel, i accidentally fitted the feed to the wrong barb when checking fuel pressure and only realised something was amiss when it dribbled out the plug hole, syringed all the plenum, bores, inlet, carb out etc to be sure it was all out, On 26th Jan, 2012 Tom Fenton said:
4th Dec, 2014 at 06:03:27pm
Wintersurfers needed an oil change too. We all make mistakes. It's the best way to Learn. In the 13's at last!.. Just |
4th Dec, 2014 at 10:31:22pm
ok cheers guys will double check everything again, have ordered an overhaul kit tonight to just incase. |
4th Dec, 2014 at 11:11:55pm
Pop a picture up showing your carb and regulator, so we can see your plumbing. In the 13's at last!.. Just |
5th Dec, 2014 at 12:08:02am
www.turbominis.co.uk/forums/index.php?p=vt&tid=6298
Edited by TurboDave16V on 5th Dec, 2014. On 17th Nov, 2014 Tom Fenton said:
6th Dec, 2014 at 09:21:30am
have double checked and i have got it exactly like on the turbo minis site, thats what i originally used, will take carb off today clean everything out and fit new overhaul kit and then run pump with carb off engine so i cant fill it up again lol
Page: |
