Page: |
Home > Non-Mini Projects > Metro Turbo Van | |||||||
12 Posts Member #: 9802 Member Derby |
28th Nov, 2014 at 11:09:10pm
10020 Posts Member #: 1456 Mongo Barnsley, South Flatcapshire |
28th Nov, 2014 at 11:13:21pm
Cool! Look forward to seeing progress. Have a search on here and you will find the turbo van Andy and I had a few years ago! I see you aren't far away, I may have a few metro bits left in my shipping container you can have. If something is worth doing, it's worth doing half of. |
9502 Posts Member #: 1023 Post Whore Doncaster, South Yorkshire |
28th Nov, 2014 at 11:16:33pm
cool another one , last time i was in a metro turbo van i was nearly scared to death, well it was either the van or ^^Johns driving
Yes i moved to the darkside
28th Nov, 2014 at 11:16:35pm
28th Nov, 2014 at 11:24:12pm
I like those wheels! not too sure about thw walnut door trims though LOL
28th Nov, 2014 at 11:39:07pm
Hi John, any bits you have about would be much appreciated !! Turbo set up is something I have got to so some digging into, but seem to be on the right forum for that ! Suspension wise it will be standard van hydrolastic units, as they were stiffer for the added carrying weight,I will also individualise each unit. Front and rear turbo anti roll bars, rear turrets so I can run adjustable shocks all round. Then brakes will be standard metro 4 pots with green stuff pads with vented and drilled discs. Got quite a few suspension bits and bobs but still a few to get. This isn't my first metro and not the only one I own either, but I do also own a couple of minis Aswell.
16540 Posts Member #: 4241 King Gaycharger, butt plug dealer, Sheldon Cooper and a BAC but generally a niceish fella if you dont mind a northerner Rotherham, South Yorkshire |
29th Nov, 2014 at 07:28:26am
It's all downhill from here...
i tried putting soap on it , and heating it to brown , then slathered my new lube on it |
3673 Posts Member #: 9300 Post Whore Quarry Bonk |
29th Nov, 2014 at 08:01:04am
Stay well away from greenstuff pads, they're utter shite! Get yourself some mintex m1144 pads, more expensive, but they actually work, and work well. Looking forward to seeing this build though, looks like you have a healthy pile of nos parts there! On 26th Jan, 2012 Tom Fenton said:
29th Nov, 2014 at 09:10:21am
I have read the build thread for the last turbo van !! Won't be making anything like the power that one was making !!! Well unless I get carried a away :/ some helpful info in the thread anyway..
6729 Posts Member #: 618 Post Whore Glasgow |
29th Nov, 2014 at 10:11:27am
Time will tell Josh! |
29th Nov, 2014 at 10:30:08am
I agree with the greenstuff comment, I'd rather std pads over the greens.
Page: |
