Home > Wanted > WANTED: A camshaft ---> MG Metro, MD256, MD266 or similar. What have you got?
PhilR
Member #: 10034
Birmingham
I Want something with low exhaust lift. I have a 998 block / 12G940 head combo, but would rather not pocket the block on this one if I can get away with it, as it may get rebuilt to a different spec at a later date.
Possibles cams so far...
MG Metro / KC500,
MD256,
MD266,
... but let me know what you've got as there may more cams that might work. If it's a not so common cam, measuring the exhaust lobe height would be really really helpful.
Cheers guys!
Edited by PhilR on 24th Nov, 2014.
Oli
Member #: 1910
Wilts
Sure I've got a standard 1275 cam
PhilR
Member #: 10034
Birmingham
I have got is a standard 1275 profile and have been tempted to just use that as it looks better than the standard 998 ones, but I don't want to regret it later on once the engines fitted and running.
