Page: |
Home > General Chat > Podifold | |||||||
16th Nov, 2014 at 08:56:49am
Hey guys
16th Nov, 2014 at 09:40:41am
I can't comment on the design and I guess a lot will depend on some testing in both performance, setup, and if it lasts.
16th Nov, 2014 at 09:58:58am
I like the concept, and I think it will work fairly well, But...
16th Nov, 2014 at 10:17:57am
I know Joe I want to supercharge my Mini and its a 998.
16th Nov, 2014 at 01:36:25pm
Never been tested, therefore it should not be on the market. It could create all sorts of running problems, it needs to have been run reliably for a few thousand miles before even thinking about making and selling them. On 26th Jan, 2012 Tom Fenton said:
64 Posts Member #: 10995 Advanced Member North Yorkshire |
16th Nov, 2014 at 03:06:06pm
Just sent them an email so lets see what comes back. I may consider this route if feasible. Class D Winner 1997 - 1998 - 2003
![]() 1043 Posts Member #: 10424 Post Whore Swansea boyo! |
16th Nov, 2014 at 04:21:57pm
REALLY?! They haven't even been tested properly yet! I'm so surprised it's been posted in mini mags ect..
On 16th Nov, 2014 Cantelo said:
Just sent them an email so lets see what comes back. I may consider this route if feasible. They don't die, they just get faster! |
16th Nov, 2014 at 04:32:54pm
You need to understand my definition of feasible!!!
On 16th Nov, 2014 Shauna said:
REALLY?! They haven't even been tested properly yet! I'm so surprised it's been posted in mini mags ect.. On 16th Nov, 2014 Cantelo said: Just sent them an email so lets see what comes back. I may consider this route if feasible. Class D Winner 1997 - 1998 - 2003
16th Nov, 2014 at 05:29:28pm
Hahaha! Maybe you should stay away from TMF where he has said himself he hopes his engine doesn't blow up when it goes on the rolling road, fills you with confidence On 16th Nov, 2014 Cantelo said:
You need to understand my definition of feasible!!! On 16th Nov, 2014 Shauna said: REALLY?! They haven't even been tested properly yet! I'm so surprised it's been posted in mini mags ect.. On 16th Nov, 2014 Cantelo said: Just sent them an email so lets see what comes back. I may consider this route if feasible. They don't die, they just get faster! |
16th Nov, 2014 at 06:50:41pm
WAY to expensive. Other than that beats the other options really so fair enough. |
16th Nov, 2014 at 07:19:08pm
I like the concept, however, all these blow through set ups overlook one significant fundamental operating condition! Engine overrun!
16th Nov, 2014 at 07:22:33pm
On 16th Nov, 2014 Chalkie said:
what other options are there I know Graham & Andy has the SC12 Setup that kit comes from Auz then finding a charger like finding hens teeth. i know of a complete settup good to go, just came off a 998 local lad to me hes looking for £800 atm its only been advertised localy so far edit: my opinion to the 'podifold' you could make one for less....if your happy to use stainless i bet £150 quid and a couple weekends work Edited by Brett on 16th Nov, 2014. Yes i moved to the darkside |
16th Nov, 2014 at 07:49:02pm
It took johnnysti and Slark nearly 12 months to overcome the issues with a blowthrough set up and it sounded gash!
16th Nov, 2014 at 07:55:50pm
yeaah but suck through carbs are.... hazardous,
16th Nov, 2014 at 08:41:03pm
could you have a throttle pre-charger and an SU with no throttle plate post charger, because of the way the SU works this may be a viable option :) turbo 16v k-series 11.9@118.9 :)
16th Nov, 2014 at 09:46:15pm
maybe turbo will be safer then bmw made it work with the r53 so how hard can it be? the throttle is infront of the charger so. |
16th Nov, 2014 at 10:16:49pm
On 16th Nov, 2014 evolotion said:
could you have a throttle pre-charger and an SU with no throttle plate post charger, because of the way the SU works this may be a viable option :) why struggle on with a carb, when fuel injection is perfect for this. I suppose it depends on which EFi school you attend ![]() On 26th Oct, 2004 TurboDave16v said:
16th Nov, 2014 at 10:21:15pm
n bmw made it work with the r53 so how hard can it be? the throttle is infront of the charger so. Exactly, throttle pre supercharger, huge recirculation valve post supercharger, and all rigid charge air ducting, then of course, fuel injection. I didn't say it was hard, but rather most seem to overlook what manufacturers have spent millions on developing. On 26th Oct, 2004 TurboDave16v said:
16th Nov, 2014 at 10:23:08pm
true,
17th Nov, 2014 at 10:28:36am
could you have a throttle pre-charger and an SU with no throttle plate post charger, because of the way the SU works this may be a viable option :) why struggle on with a carb, when fuel injection is perfect for this. I suppose it depends on which EFi school you attend ![]() because having a blow through hif and throttle pre-charger doesnt compute. obv such a setup is a no brainer with EFI. on the same note, why struggle with the a-series ![]() turbo 16v k-series 11.9@118.9 :)
17th Nov, 2014 at 05:38:30pm
could you have a throttle pre-charger and an SU with no throttle plate post charger, because of the way the SU works this may be a viable option :) why struggle on with a carb, when fuel injection is perfect for this. I suppose it depends on which EFi school you attend ![]() because having a blow through hif and throttle pre-charger doesnt compute. obv such a setup is a no brainer with EFI. on the same note, why struggle with the a-series ![]() On 26th Oct, 2004 TurboDave16v said:
18th Nov, 2014 at 12:14:28am
why struggle with the a-series ![]() A question i kept asking my self for far too long Yes i moved to the darkside |
![]() 324 Posts Member #: 9441 Senior Member South Devon |
18th Nov, 2014 at 08:29:00pm
I like the concept, however, all these blow through set ups overlook one significant fundamental operating condition! Engine overrun! The throttle should ALWAYS be infront of the supercharger! I'm glad you said that before I got to far with my set up. I'm going to re configure to this now. ![]() |
9 Posts Member #: 10951 Junior Member |
8th Dec, 2015 at 08:56:58pm
For anyone who's interested, here's a link to my first engine running using a Podifold manifold
8th Dec, 2015 at 11:19:27pm
Lol, ok it idles.
Page: |
