| Home > Technical Chat > Helical gearbox failure modes | |||||||
5th Nov, 2014 at 11:29:55pm
I've seen of a few failed helical boxes on the forums recently and broken a few myself, which has gotten me thinking... If certain parts fail at certain power / torque / RPM levels, can you work around these problems?
5th Nov, 2014 at 11:44:00pm
In my opinion, the first motion and thid motion shafts ae being pushed away from the laygear under load. the input gear support beaing reduces the first motion shaft movement. However, the third motion shaft is only supported at one end. The torque though third gear pushes the shaft away fom the lay gear, and is compounded by the pinion pushing away fom the crownwheel. the little nose beaing in the end of the first motion shaft, and the support bearing are trying their best to prevent any movement.
6th Nov, 2014 at 02:03:12am
I still am not convinced by the KAD setup personally... We have seen very few (if any?) failures of the mainshaft (3rd motion if you wish) at the pinion in front-wheel drive minis, which the support seems to suggest it helps solve?
6th Nov, 2014 at 02:08:07am
And to answer the OP's question: On 5th Nov, 2014 PhilR said:
Is 200 BHP possible with a helical box??? Of course it is... Torque limit in 1, 2, 3, and also 4th, to keep that nasty mid-range torque from ever sullying those helical gears, and start to only build real boost in 4th after 4000 rpm - but not all at once lol... On 17th Nov, 2014 Tom Fenton said:
