Home > Wanted > Long bolts for plenum chamber
franky4x4
Member #: 10948
swansea. south wales
Hi all after the 2 long bolts that go through the plenum to the carb face! Have looked online can't even find a part number let alone the bolts! Pm if you got any spear laying around!
Cheers guys!
Your here for a good time! Not a long time!
http://s1347.photobucket.com/user/franky4x44/library/
Mate have a search on tm i have posted the thread and length a couple times just stick these in ebay and you can buy them next day delivery
franky4x4
Member #: 10948
Ok cheers mate, I keep forgetting to use the search feature on here! I shall do so now!
franky4x4
Member #: 10948
Found them. 5/16 unc x 3" my plenum is off a maestro turbo will they still fit?
Yeah, should do, same plenum! 3" x 5/16 unc stainless allen head bolts are what i ordered for shaunas, they were about 3 or 4 quid i think
Edited by Carlzilla on 3rd Nov, 2014.
Bear in mind you won't get allen bolts out with the carb fitted to the engine. Hex bolts allow a spanner down the back, just...
franky4x4
Member #: 10948
Yea iv ordered 2 now hex bolts £2.69 and free p&p
obvs never watched me do it then? *happy*
welshdan
Member #: 1111
s wales
are these the ones? could do with a set myself
http://www.ebay.co.uk/itm/5-16UNC-x3-HT-HE...=item337ca18466
clubbie nl
Member #: 7701
Amsterdam Holland
The 2 long bolts , from the engine steady under the radiator , seem to be the same.
Using them for a dry build right now.
It's a little car .... eating big money
Diff studs also work i believe, and two of the rocker studs can't remember if its the short or long ones now.
franky4x4
Member #: 10948
No mine were zinc plated.
