Home > For Sale > IHI RHF4 almost new turbo well suited to small bore
mayoturbo
Member #: 1395
chepstow
IHI rhf4 as12 turbo. Nice small and compact turbo.
There are a few on here which have used the same turbo on small bore A-series with good results. This turbo has barely been used and is almost new.
£150
mayoturbo
Member #: 1395
chepstow
I still have this for sale
tadge44
Member #: 2500
Buckinghamshire
Can I see a picture of the exhaust flange please ?
(I,m looking at it to see if it can be adapted to use the Metro turbo manifold)
It's a square mounting Dave..... have a look here at the one I sold a few years back http://www.turbominis.co.uk/forums/index.php?p=vt&tid=306641
tadge44
Member #: 2500
Buckinghamshire
Thanks Colin.
I was thinking of using this on a 1275 with the expectation of less lag and quicker spool up. The GT1752 is OK, but there is still more lag than I would like. 140bhp in the blobule is quite enough !
mayoturbo
Member #: 1395
chepstow
Yes it is a square flange. Would you like me to get some measurements for the flange?
tadge44
Member #: 2500
Buckinghamshire
That would be helpful - thank you
mayoturbo
Member #: 1395
chepstow
its 48mm center to center from the hole to the hole next to it
68mm center to center measuring diagonally between holes.
The manifold to turbo gasket for my charade gtti fits perfectly, I have an old metal gasket I could include.
Hopefully of some help
