Page: |
Home > A-Series EFI / Injection > Wideband Accuracy | |||||||
![]() 8604 Posts Member #: 573 Formerly Axel Podland |
25th Oct, 2014 at 10:15:32am
Following on from Graham T's thread "1312cc Ti", where there was a frank exchange of views about the accuracy of the 0-5v output from wideband gauges. Opinions are obviously polarised, but there does not seem to be anything other than anecdotal evidence mainly from people on the MS Forums reporting differences in the AFR reported by the gauge and that displayed in logs or Tuner Studio. I don't know if other tuner forums are reporting similar issues.
25th Oct, 2014 at 10:32:03am
interesting, thoughts,
![]() 5988 Posts Member #: 2024 Formally Retired Rural Suffolk |
25th Oct, 2014 at 11:17:56am
Yes, interesting thoughts.
25th Oct, 2014 at 11:58:23am
On 25th Oct, 2014 Rod S said:
and there was always a 0.1 - 0.2 difference. So, lets get this right, you are talking about an error of less than 2% ? Edited by Paul S on 25th Oct, 2014. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
25th Oct, 2014 at 12:27:34pm
On 25th Oct, 2014 Paul S said:
So, lets get this right, you are talking about an error of less than 2% ? Yes, if referenced against 14.7 But, like I said, that's on a setup I consider to be totally noise free and with near perfect grounding regimes (I've have NEVER had any synch issues apart from changing the pot setting between JimStim and engine) and most of the analogue issues that others report come down to noise/grounding (as you have already suggested). If you want a comparison with an "average" setup it's all on the MS-E forums. It would be difficult for me to replicate an "average" setup without deliberately badly re-wiring everything. It's back again to your thoughts on making it simple or doing it right ![]() Schrödinger's cat - so which one am I ??? |
![]() 696 Posts Member #: 10034 Post Whore Birmingham |
25th Oct, 2014 at 01:37:19pm
I installed an AEM controller / display on the dashboard and used the 0-5V ouptut to talk to Megasquirt.
Edited by PhilR on 25th Oct, 2014. |
25th Oct, 2014 at 02:03:37pm
Good point.
25th Oct, 2014 at 02:22:53pm
I had the gauge on the dash to compare them side by side, so it was obvious from the start. With no gauge, most people would make a huge assumption that the figure their ECU sees is correct - not good.
25th Oct, 2014 at 02:47:08pm
Lifes too short to worry about 2%.
25th Oct, 2014 at 02:56:57pm
If you KNOW you only have 2% and are happy with it, that's fine be me.
25th Oct, 2014 at 03:28:49pm
The way I was rebuked yesterday for suggesting that you could just connect the 0-5v directly to the ECU gave me and possibly others the impression that the level of inaccuracy was far greater, say 5-10%, in which case it would be worth doing something.
25th Oct, 2014 at 04:10:26pm
At the risk of repeating myself I said I have seen +/- 2%
25th Oct, 2014 at 04:14:02pm
The way you were rebuked?
25th Oct, 2014 at 04:17:22pm
As for simplicity, there is a controller being tested that will only require a CAN connection and it will automatically detect if it is connected to an MS2 or MS3 and send the data to the correct location. Settings on the MS2/MS3 will be minimal and the same as they would be for a 0-5V connection. |
25th Oct, 2014 at 04:41:29pm
I have a blitz ecu display in the skyline along with an aem in narrowband mode and at certain points i was getting the blitz saying 0.85lambda and the aem 14afr
Yes i moved to the darkside |
25th Oct, 2014 at 06:25:06pm
To confirm, the 1-2 AFR difference that I saw was due to calibration. Figures around 14.7 were spot on, then either side of stoich the AFR got further out: +2 AFR at one extreme and -2 AFR at the other end; Not something that I'd put down to a connection problem.
An tolerance of +/- 2% will have absolutely no impact on the way you set the car up or its performance. I completely agree. You can test the sensor with lab gas and say it's accurate to perhaps +- 0.1 AFR and you can know that the digital output is spot on, but it's still a piece of voodoo that's trying to estimate the AFR in a very dynamic environment. We've already heard that the distance you place the sensor from the engine, (NA and post turbo) causes a small but measurable difference in readings. You can't take the AFR as 100% accurate. |
25th Oct, 2014 at 06:53:21pm
One issue with wideband controllers is that they are not ratiometric devices like all the other standard sensors used with the ECU. And since they have their own 5V reference, if the manufacturing tolerances are too large (like they seem to be on many AEM units) you end up with a wrong calibration. Having to create your own calibration curve instead of using the manufacturer standard curve does not make sense and is not something everyone will be comfortable with or even able to do.
Edited by jbelanger on 25th Oct, 2014. |
25th Oct, 2014 at 07:50:11pm
To test the rich value, I plan on using unburnt hydro-carbon in the form of LPG. The chemistry of Lambda sensors do not 'read' HC, they read 'CO' On 26th Oct, 2004 TurboDave16v said:
25th Oct, 2014 at 08:43:36pm
To test the rich value, I plan on using unburnt hydro-carbon in the form of LPG. The chemistry of Lambda sensors do not 'read' HC, they read 'CO' Does a butane lighter emit CO? Take a fully on unlit butane lighter and place it under a wideband sensor and see what AFR or Lambda you get (hint: full rich for that controller). Edited by jbelanger on 25th Oct, 2014. |
25th Oct, 2014 at 09:15:13pm
The chemistry of Lambda sensors do not 'read' HC, they read 'CO' Nope, I'm being pedantic but they measure O2 (for what ever difference that makes - it's still all voodoo to me) EDIT UPDATE: With regards to Jean's butane example, I see this as the butane displacing all the oxygen in the air, not the sensor actually measuring hydrocarbons. Maybe using a lighter is just about the simplest way of doing this with whatever is at hand. I'd guess that welding argon would give the same rich result. Jean, the 5V output should be a proportional straight line, not a curve. It's not like reading the actual voltage of a narrowband sensors element and mapping it to AFR. Without a gauge on the controller itself there's no way I would have known the 5V was so far out. I did try the published calibration data from AEM and also other manufacturers, but I have no idea how AEM managed to get it so far off? I've also read about issues from the shared heater ground line upsetting the 5V output, although this wasn't a problem on mine. Generally, I agree that digital wins when compared to the 5V signal, but this is still only one of many sources of potential errors. For example, on my NA engine I mounted mine pre-cat. If I'd known they were sensitive to back pressure, I may have welded it in it post-cat. Edited by PhilR on 25th Oct, 2014. |
25th Oct, 2014 at 09:42:16pm
I don't know enough about the way the sensor works to say exactly what goes on with the butane but I do know that it is a bit more complex than that. The sensor actually "breathes" O2 from its wiring loom and the cell pump current to come to a Lambda 1.0 mix in the cell is what the controller uses to compute the Lambda value at the sensor.
25th Oct, 2014 at 09:52:39pm
It might be of interest to those who want to see more about how the sensors work: http://www.megamanual.com/PWC/LSU4.htm
25th Oct, 2014 at 11:33:33pm
Surely the sensors themselves have a tolerance that would need factoring in? I run a supercharger and I don't care the TB is on the wrong side.
26th Oct, 2014 at 12:10:55am
There is a laser etched resistor in the connector. That should be used by the controller to adjust to the sensor. Some controllers do not use it. I know the 14point7 controllers do make use of it. Others claim that free air calibration is sufficient. |
26th Oct, 2014 at 12:23:47am
So would the same idea follow that some of the tolerance could also come from the controller hardware and code then? I run a supercharger and I don't care the TB is on the wrong side.
Page: |
