Page: |
Home > Wanted > mk1 parts | |||||||
1750 Posts Member #: 10190 Post Whore belgium |
15th Oct, 2014 at 07:41:27pm
hi
15th Oct, 2014 at 09:11:50pm
I think swiftune do the oval spacers IIRC |
16th Oct, 2014 at 05:17:39am
I found a stud kit for the subframe but not the plates on there website. . you can do anything if you set your mind to it...
4890 Posts Member #: 1775 Post Whore Chester |
16th Oct, 2014 at 07:17:22am
I found an old post from Paul who recommended the minispares alloy hinges which I swapped to when I had the car painted. That way you stop the rust! I run a supercharger and I don't care the TB is on the wrong side.
16th Oct, 2014 at 02:53:20pm
I have been looking at those and talked about it at the painters. There fear is that they would oxidate and paint would brake of at the hinge point. Or is this not something to worry about with the right primer. you can do anything if you set your mind to it...
3673 Posts Member #: 9300 Post Whore Quarry Bonk |
16th Oct, 2014 at 04:18:50pm
Steel oxidises too, it's rust, just etch prime and paint as normal. Manufacturers make body panels out of the stuff. Edited by Carlzilla on 16th Oct, 2014. On 26th Jan, 2012 Tom Fenton said:
16th Oct, 2014 at 07:58:46pm
Mine have been ok for 3 years so far? I run a supercharger and I don't care the TB is on the wrong side.
Page: |
