Page: |
Home > Show Us Yours! > Budget Turbo Port Injection | |||||||
![]() 8604 Posts Member #: 573 Formerly Axel Podland |
9th Oct, 2014 at 10:51:02am
We have already fuel injected my lads Mini 30:
Edited by Paul S on 9th Oct, 2014. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
974 Posts Member #: 3228 Post Whore North of the Netherlands |
9th Oct, 2014 at 12:21:18pm
This should be interesting...
Dazed and Confused.... |
9th Oct, 2014 at 01:06:51pm
LCB style turbo manifold will yield considerable power gains according to my simulations. Time will tell.
![]() 696 Posts Member #: 10034 Post Whore Birmingham |
9th Oct, 2014 at 02:59:38pm
I'd like to see the inlet manifold when it's done. I'm using the SPI manifold and may need to add 2 more injectors (2+1 staged). |
9th Oct, 2014 at 03:05:57pm
The other thing that will need changing is the throttle body. The MPi one is plastic and can't be trusted at boost.
89 Posts Member #: 2380 Advanced Member Hamburg, Germany |
9th Oct, 2014 at 03:46:48pm
they have the same bolt pattern.
On 9th Oct, 2014 Paul S said:
The other thing that will need changing is the throttle body. The MPi one is plastic and can't be trusted at boost. Anyone know if the Rover 25/45/MGF throttle bodies are the same bolt pattern? Looks like they are but anyone got one to measure off? |
9th Oct, 2014 at 04:25:13pm
Thanks.
9th Oct, 2014 at 05:21:09pm
Interesting, I'll be following this. On 7th Nov, 2008 Nic said:
9th Oct, 2014 at 06:59:11pm
I've got a couple of rover TBs if you need one. On 11th Feb, 2015 robert said:
i tried putting soap on it , and heating it to brown , then slathered my new lube on it ![]() |
9th Oct, 2014 at 07:29:43pm
now i feel like i can comment Yes i moved to the darkside |
9th Oct, 2014 at 07:32:29pm
Yes, this could well end up with a GT1749V on it. Actually more than likely. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
9th Oct, 2014 at 07:33:26pm
On 9th Oct, 2014 apbellamy said:
I've got a couple of rover TBs if you need one. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
510 Posts Member #: 1592 Smart Guy! mainland europe near ze germans |
9th Oct, 2014 at 07:41:06pm
Very nice clean install On 9th Oct, 2014 Paul S said:
LCB style turbo manifold will yield considerable power gains according to my simulations. Time will tell. Interesting, what do you use for simulation ? That sir, is not rust, it is the progressive mass reduction system
9th Oct, 2014 at 07:44:15pm
Yes. By full I assume you mean the throttle disk turns through 90 degrees. If so, pm me your address and I'll pop it in the post. On 11th Feb, 2015 robert said:
133 Posts Member #: 476 Advanced Member The Black Countraaaaay |
9th Oct, 2014 at 10:39:10pm
I think the guy at VMAX did an injection set up so he could back up his comparison figures against the injected supercharger kit they sell so might be worth a call to compare notes Masturbation is not a crime its a hobby |
10th Oct, 2014 at 03:47:54pm
Yesterday, I found myself telling Brett that he could achieve 100hp with a single 800cc/min in each port. That much is true.
13th Oct, 2014 at 03:42:01pm
Nice little TB arrived in the post from the very nice Mr Bellamy Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
13th Oct, 2014 at 06:56:20pm
Must have been sent it by a distant relative... On 11th Feb, 2015 robert said:
24th Oct, 2014 at 01:20:50pm
I've now milled the bosses:
![]() 5988 Posts Member #: 2024 Formally Retired Rural Suffolk |
24th Oct, 2014 at 01:40:37pm
On 24th Oct, 2014 Paul S said:
Now need to build up courage to weld the bosses in ![]() With such a neat fit, have you considered one of the modern epoxy adhesives for alloy ? Even with a couple of additional pins or small screws it would avoid all the inevitable distortion you would see on the head face flanges with welding. Schrödinger's cat - so which one am I ??? |
24th Oct, 2014 at 01:51:41pm
I'm very tempted to use that Durafix Easyweld that I've used on the other injection bosses. No distortion. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
24th Oct, 2014 at 04:05:52pm
Just tack in place, then weld it using a small tungsten, welding the same path on each intake runner. There should be no issues of distortion. You have a mill, so a quick flash of the flanges to ensure they are flat would be cake. Edited by TurboDave16V on 24th Oct, 2014. On 17th Nov, 2014 Tom Fenton said:
24th Oct, 2014 at 06:14:09pm
Paul, not to be a kill joy but it looks like the throttle cable will fowl on the manifold, are you able to move it around to make it work? Isambard Kingdom Brunel said:
24th Oct, 2014 at 06:36:07pm
Well spotted. We are going to have to fit a different quadrant to the TB. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
24th Oct, 2014 at 07:47:05pm
i found welding cast manifolds to be a breeze, and my tig skills are almost non existent
Page: |
