Home > Beginners Tech > Metro Turbo inlet manifold porting
carl talbot
Member #: 1323
Do people do anything to radius the outer ends of the 'log style' manifold
It seems to be a really poor flow area
Was thinking of building it up with some chemical metal to give a nice outer radius
Honest dont bother, British Leyland got this item spot on ...
carl talbot
Member #: 1323
Nothing better than advice from someone with experience .
just out of interest, does the visibly horrible squared/dished ends of the 'log' tube create some sort of vortices that help the flow around the 90deg. bend .
It looks to the eye that it would be the perfect place for fuel drop out ?
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
i dont think theirs much chance of mixture separation in there due to the sort of small CSA and rather tight winding bends in it this all make the mixture move quite fast and violently helping it stay as it should
imo its more likely when the intake CSA is huge and straight where the mixture speed is low then its likely to drop out but not so much when there is good mixture speed and a rough surface
Sir Yun
Member #: 1592
Smart Guy!
When you test on a flowbench you have a lot of things that work fine, even though it looks wrong and lots of things that look great but don't work at all
I had Turbophil just tidy up mine, he did the entrance and exits on it which is now fitted to shaunas car, he's not touched anything else in the manifold so I would say he too knows that it's best not mess too much with it.
carl talbot
Member #: 1323
its just that people spend so much time and effort on flowing inlet and exhaust ports on a head and then to bolt on something with such visible hideous restrictions ?
difficult to get in there and do much about it anyway
fixitphil2
Member #: 10945
scarborough/ northyorkshire
what about using a na one off a mg metro? thats what im going to use, looks a better flowing manifold but as said dont meen it will be
slater
Member #: 1291
Suffolk / Birmingham
Its not all about how much it flows.
D4VE
Member #: 10749
lowestoft suffolk
Years back i cleaned up my inlet and then got told 'ya shouldnt of done that' apparently being turbo the roughness helped 'mix' the air n fuel at the speed its being forced in anyway??
Nothing gets past Dave lol
