Home > Technical Chat > Boot floor and battery box weight
alaskanow0
Member #: 8466
Mansfield
Anybody know the weight of the battery box and boot floor. I'm considering fitting a composite boot floor. I heard mixed messages about the weight saving. Battery box on Amazin states 7kg, which surely isn't correct.
The replacement panels weights 1.4
D4VE
Member #: 10749
lowestoft suffolk
I cant see it being 7kg but slightly weightier than the rest of the floor, ive heard theres not much in it?
Edited by D4VE on 30th Sep, 2014.
Nothing gets past Dave lol
dont do it matt IMO it wrecks a mini,
you would be better off loosing the rear subby and running gear for a beam type made of titanium from uncle carl
is the way to go
alaskanow0
Member #: 8466
Mansfield
I made the decision to remove the battery box either way.
Steve I've already got a 3kg rear beam, and pretty light running gear. I'm turretting and tubbing the rear arches anyway.
I know what you mean though, but the rest of the car is already cut up. Ie. Flip front, turbo box, Webber box, back seats, bins etc.
t3gav
Member #: 229
Gavin@minispares.com
kent
Battery box is 1.123kg by itself, complete boot floor and box is 6.8kg approx.
alaskanow0
Member #: 8466
Mansfield
That's great thanks.
Is that for a new complete floor, or what you cut out for the new carbon floor?
Edited by alaskanow0 on 1st Oct, 2014.
Be careful Matt! A stiff breeze and it may blow away!
t3gav
Member #: 229
kent
That's complete floor.
alaskanow0
Member #: 8466
Mansfield
Not with me sat in it😃
D4VE
Member #: 10749
lowestoft suffolk
Blimey it is 7kg then... wouldnt of thought or guessed that? Anyway all this work on ya mini.. get some pics up
alaskanow0
Member #: 8466
Mansfield
In good time Dave.
I reckon from the bit you cut out is about 3.2kg, so saving would be about 2kg. That's with a genuine carbon fibre panel.
Worth it? Not sure, blanking the battery box as got to be worth 0.75kg
t3gav
Member #: 229
kent
Remember the boot floor is part of the rear seat, it's quite a big panel!
Aubrey_Boy
Member #: 9962
Steve I've already got a 3kg rear beam.
Hi there,
What rear beam is that? And what does 3kg include? Camber and toe adjustment and handbrake cable fixing / routings? Does it take a std trailing arm?
Sorry for the numerous questions, just interested
alaskanow0
Member #: 8466
Mansfield
It's a KAD beam for normal arms. It weighs exactly 3kg, not including any brackets and bolts. They weigh another 2.25kg in total from memory. The brackets are really thick and strong though.
Aubrey_Boy
Member #: 9962
That's great thank you, so difficult to get genuine weights for anything.
If you don't mind me asking, what weight did the SC trailing arms come in at in a comparable weight to the KAD arms, say with the pivot pin etc
i understand now matt
