Home > Wanted > 12g940
Hi all I'm starting to look for a 12g940 for my small bore. I'm looking for one that has the std 33mm valves. the heater takeoff and the bypass, but let me know what you have.
It would be great if it had a large cc in it....
I'm also not sure what these are worth?
Thanks
Graham
They seem to average around £40 so don't pay too much over the odds
Sean1
Member #: 10798
I sold one previous for 50 odd and I've seen them go for around 80 I have a genuine turbo one with double valve springs and told new guides they do look like brass ones I was looking for 80 as I'm not going to use it but it doesn't have the bypass and iirc the heater take off is blanked
Sean1
Member #: 10798
Just thought the turbo heads have the blanking screw for bypass so you could maybe make something up?
I've got a few at home. Will check valve sizes when I'm back in blighty.
Hi Sean I have pm'd you
Thanks Andy having a good holiday I hope mate? Speak to you when your back
graemec
Member #: 1424
Carnforth, Lancs
Think I have one Graham if you're up at your folks anytime?
