Home > Technical Chat > turbo inlet
braziers
Member #: 10957
sussex
is the metro turbo intake manifold shorter in length than the alloy mg nat. asp. manifolds or are they the same
the metro turbo inlet manifold is a log type manifold, it stays quite high up and drops down between the exhaust manifold runners,
not all alloy inlet manifolds will fit ( if any ), ive tryed 2 other than the metro one, neither would fit without work and if they did the flanged are too thin on the head side
