Home > For Sale > Taking To Mini World Action Day Castle Combe 27Th - Fibreglass Dash + Gauges
Mowen123
Member #: 5593
Taunton, South West
NEW - Custom Fibreglass Dash - £140
NEW - D1 Spec Oil Pressure Gauge - £75 (http://www.epracing.co.uk/Performance-Electronics/Performance-Gauges/D1-Spec-Gauges/60mm-White-Face/D1-Spec-Oil-Pressure-Gauge-60mm/p-748-168-738-767-2737/)
NEW - D1 Oil Temp Gauge - £65 (http://www.epracing.co.uk/Performance-Electronics/Performance-Gauges/D1-Spec-Gauges/60mm-White-Face/D1-Spec-Oil-Temp-Gauge-60mm/p-748-168-738-767-2735/)
See individual ads for more info
PM me or contact on 07876 573894
http://i423.photobucket.com/albums/pp316/M...zpsdbcf5b0c.jpg
http://i423.photobucket.com/albums/pp316/M...zps60fe601d.jpg
http://i423.photobucket.com/albums/pp316/M...zps40b18e50.jpg
http://i423.photobucket.com/albums/pp316/M...zpsf7bd0209.jpg
http://i423.photobucket.com/albums/pp316/M...zps61c5374e.jpg
http://i423.photobucket.com/albums/pp316/M...zps20ce7b70.jpg
bakker110
Member #: 9367
Derby
Sorry I'm not interested just a little confused how you'd ever get the cage legs through the dash. I assume it's pretty rigid being fibreglass therefore rather awkward.
Mowen123
Member #: 5593
Taunton, South West
It is indeed rigid - You unbolt the front legs from the rest of the cage, lean them out of the door apertures to create just enough space to allow the dash to pass between them, lean the front cage legs back into the car and simultaneously into the channels moulded into the dash, and then do everything back up. It's easy
I had a 2" rollcage going through them, so that more than covers all the other smaller diameter cages people use.
