Page: |
Home > Show Us Yours! > Made in Poland | |||||||
95 Posts Member #: 10924 Advanced Member Wroclaw/Poland |
22nd Sep, 2014 at 08:54:41pm
Hi guys,
Made in Poland build thread:
7265 Posts Member #: 1268 The Boom Boom speaker Police! Essex |
22nd Sep, 2014 at 09:16:15pm
Sounds very realistic and should be easily achievable.
In the 13's at last!.. Just |
23rd Sep, 2014 at 12:17:24am
Czesc,
23rd Sep, 2014 at 06:50:07pm
I'm planing on at least having exhaust prepared to plug in this to tune the carb properly:
11046 Posts Member #: 965 Post Whore Preston On The Brook |
23rd Sep, 2014 at 07:17:17pm
MMM, thats a bit fucked On 26th Oct, 2004 TurboDave16v said:
23rd Sep, 2014 at 08:07:18pm
yup. however I found a company here in Poland that claims they can deal with it. They will need a flywheel to sort out cone dimensions, but since they estimated the cost at around 25-30quid I might give it a try.
9812 Posts Member #: 332 Resident Cylinder Head Modifier Mitsi Evo 7, 911, Cossie. & all the chavs ...... won no problem |
23rd Sep, 2014 at 08:16:31pm
On 23rd Sep, 2014 Sprocket said:
MMM, thats a bit fucked agree with colin its well goosed, if they can do it for that money it will be worth it
23rd Sep, 2014 at 08:50:31pm
Question
23rd Sep, 2014 at 08:50:35pm
Question
24th Sep, 2014 at 06:53:51pm
I guess that's what the machine shop will do more or less.
24th Sep, 2014 at 07:23:34pm
Avoid minisport x pin.
25th Sep, 2014 at 01:09:43am
On 23rd Sep, 2014 SadamPl said:
Anyway my concerns are now focused on something else... This might help: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=558858 On 17th Nov, 2014 Tom Fenton said:
26th Sep, 2014 at 09:46:09pm
I prefere to be on a safe side with the drivetrain, so I may drop the idea of SC gears but probably only if the budget will be tight.
2974 Posts Member #: 10749 Post Whore lowestoft suffolk |
26th Sep, 2014 at 09:59:59pm
Weird find!? Whats the plan with the water pump hole? On 24th Oct, 2015 jonny f said:
Nothing gets past Dave lol NOTHING GETS PAST ME!! 1/4 mile 14.7 @ 96mph 12psi boost Showdown class A 2nd place 18.6 @ 69mph |
26th Sep, 2014 at 10:26:49pm
Water pump hole was enlarged a bit towards the back of the block and the edges were rounded to help water flow.
26th Sep, 2014 at 10:46:28pm
Ah yes i see now what youve done! I wonder if the drill bit caused a former owner a massive annoyance of a certain rattle that he could never find the problem? Haha On 24th Oct, 2015 jonny f said:
27th Sep, 2014 at 11:58:05am
I'm liking the attention to detail and reserch going on here.
27th Sep, 2014 at 07:33:24pm
D4VE, I don't think there was any noise that you could hear, drill was siting tight inside the water way. I didn't even noticed anything until I took a closer look at it.
1st Oct, 2014 at 11:33:34am
I'm slowly finalizing my parts order, at first I'm going to get all of the things to assemble the short block:
1st Oct, 2014 at 02:20:19pm
Minispares have a selection of bearings - so shoud have what you want. I've bought most of my rebuild parts from them (including bearings and pistons). Luckily, they're only a few miles down the road from me but if I needed stuff posting I'd trust them to get it right.
Edited by PhilR on 1st Oct, 2014. |
1st Oct, 2014 at 02:31:27pm
I should have been more clear. What I mean is whether I should buy standard oversize bearing offered by Minispares and other parts supliers - probably Glyco or Mahle or should i look for something more fancy? Made in Poland build thread:
1st Oct, 2014 at 02:49:58pm
I think mine were a mix of Mahle and AEM from Minispares, they looked good enough to me, but sorry, I can't advise past that.
10th Oct, 2014 at 05:26:07pm
Not much of an update as I'm waiting for the parts to arrive. Some spare time in the evening also would be nice.
46 Posts Member #: 8869 Member Porto, Portugal |
11th Oct, 2014 at 02:08:30pm
11th Oct, 2014 at 04:09:28pm
Thanks for the tip. I think there is still enough place to correct it. Checked out your site. Awesome stuff. Made in Poland build thread:
Page: |
