Home > For Sale > Avo Adjustable Miglia/se7En Rose Jointed Dampers
Tupers
Member #: 9441
South Devon
I bought these at Combe last year for a fast road project that never happened. As you can see in the pictures at the bottom two of the dampers (one front, one rear) have small dents on the outside of the bodies but they still cycle through fine with not sign of tightness. Also one of the top of the threads on the rear top mount is a little gnarled but but I'll run a die down it before delivery.
All of these adjusters move correctly and the dampers offer a good range of resistance. The fronts measure 28.5CM open & 22CM closed and the rears are 25.5CM open and 19CM closed. The shafts are 15MM, much larger and stronger than most after market dampers.
I'm looking for £200 ono inc delivery within mainland UK.
Edited by Tupers on 19th Sep, 2014.
