Home > Beginners Tech > used 1275 metro turbo engine.
nota
Member #: 10800
After buying a used engine, what would you recommend me to do first?
Edited by nota on 7th Sep, 2014.
Rebuild it probably.
slater
Member #: 1291
Suffolk / Birmingham
Yep either that or expect it to go wrong!
wng691s clubby
Member #: 9252
Cleethorpes
strip it check bearings ect
Done now needs redoing lol
Complete strip and rebuild, leave no stone unturned
nota
Member #: 10800
can you pls tell me also what parts that are critical normally=)?
just so I know more about what parts I should be searcing for.
Feels like a mr. stupid tho*tongue*
Things I would definitely replace are the oil pump, fit a Central oil pickup, hardened diff pin, relap the valves and fit new stem seals, new plugs, leads, gaskets etc
Main bearings and big ends?
Everything. Just replace all of the parts which can wear.
I was going to list each part above but everything pretty much covers it, so I pretty much thought of the bare minimum
smokestack-lightning.
Member #: 10557
As has been said on here many times in the past...(and more often than not been proved right)
...treat as though its been thrashed to within an inch of its life for 30 years with no oil in it underwater.....maybe a tad extreme but as others have found these engines seem to have had a pasting from two generations of boy racers....
*wink* not that I would do such things.....
Double-Blind experiment, N:
An experiment in which the Chief Researcher believes he is
Fooling both the subject and the lab assistant. Often accompanied by
a belief in the Tooth Fairy.
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
worth a good look over imo sounds like you need a hynase what ever its called workshope book i beleave they have a good bit in there of what to check out/normal/fucked..
myself id be seeing what the crank and bigends are an at least just get fresh shells and a new oil pump check the rings and bores for marks/were lap the valves check the guides for wear and fit new seals basicly all the parts that wear under normal conditions as already said
