Home > Wanted > Flip front hinges
evad1980
Member #: 10165
Stansted, Essex
Trying to get my hands on a set of these...
http://www.superfastminis.com/front_end_hinge_kit.htm
But... I can only find them across the pond. Anyone know if anyone does them over here in the uk?
Cant find em if they do?
You could probably rejig some modernish saloon boot hinges to do the same job.
evad1980
Member #: 10165
Stansted, Essex
True... Prob could
ok, I don't like these fronts in anyway but if you must; a neighbour of mine has made up a rather convincing similar setup using BMW 5 series boot hinges
wayne miller
Member #: 10890
Twin Cam Turbo Build In Progress Rothwell, Northants
Any Pics Gavin of the bonnet open and the hinge set up?
I'll try and get some at the weekend if he is about; its all on a steel front; the hinges are mounted on the outer edge of the inner wing at the brace point in front of the scuttle and he has welded a mount onto the underside of the wing top
