Page: |
Home > Wanted > Plenum Intake Neck | |||||||
40 Posts Member #: 3114 Member Buckinghamshire |
3rd Sep, 2014 at 09:29:12pm
Looking for a plenum intake neck that has been modified for inter cooler inlet 50 mm pipe entry or just a standard neck to cut weld modify or a nic plenum
3004 Posts Member #: 2500 Post Whore Buckinghamshire |
4th Sep, 2014 at 06:07:31am
Most just modify (weld) the existing plenum, if you have one. |
4th Sep, 2014 at 08:53:39am
Or use a piece of 2" steel exhaust pipe and a bit of steel plate and make a new one. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
4th Sep, 2014 at 08:12:53pm
On 4th Sep, 2014 tadge44 said:
Most just modify (weld) the existing plenum, if you have one. Edited by Orlando on 4th Sep, 2014. |
4th Sep, 2014 at 08:16:01pm
ya...but i just wanted to keep one as standard for a back up if i can find another standard neck i will modify that...
Page: |
