Page: |
Home > Help Needed / General Tech Chat > Slow Oil Pressure | |||||||
1st Sep, 2014 at 07:18:45am
Having just done a gearbox rebuild and dropped the engine back in, I've hit an oil pressure problem.
Edited by graemec on 1st Sep, 2014. |
1st Sep, 2014 at 08:23:41am
O ring? I run a supercharger and I don't care the TB is on the wrong side.
1st Sep, 2014 at 08:40:30am
what oil?
974 Posts Member #: 3228 Post Whore North of the Netherlands |
1st Sep, 2014 at 10:36:12am
I think Graham is referring to O-ring between block and box.. Dazed and Confused.... |
1st Sep, 2014 at 10:56:38am
This sounds like a badly machined pump if you are sure an o ring was fitted... Did you open and inspect the pump? I always do this just to make sure all is well and there is no swarf or stray casting flash ready to break off hanging around in there. A quick feeler gauge check will verify the pump clearances. On 17th Nov, 2014 Tom Fenton said:
1st Sep, 2014 at 04:18:55pm
O ring was fitted, unless it fell out when I dropped the box onto the block (if it did, it fell inside not out!). I think without the O ring I'd struggle to get any reasonable pressure at all wouldn't I?
1st Sep, 2014 at 04:47:16pm
I always gasket seal the o ring into place, that way I'm 100% sure it's not going to be a problem for me. On 26th Jan, 2012 Tom Fenton said:
![]() 5988 Posts Member #: 2024 Formally Retired Rural Suffolk |
1st Sep, 2014 at 06:09:11pm
On 1st Sep, 2014 graemec said:
I think without the O ring I'd struggle to get any reasonable pressure at all wouldn't I? No, you would just potentially be slow to get the pressure. The O ring is on the suction side of the pump so if it leaks because it is old and hard (or is omitted) the oil will slowly drain from the pump and the pump will initally suck air, not oil. Once primed, the pressure will be fine (although you will be pumping a few air bubbles as well) Gasket behind the pump is another prime suspect especially if it's not a "genuine" because these pumps stupidly have only two bolts and the aftermarket gaskets are too thin. Schrödinger's cat - so which one am I ??? |
1st Sep, 2014 at 06:46:55pm
Sounds like either way it's a pull it apart and check I run a supercharger and I don't care the TB is on the wrong side.
1st Sep, 2014 at 07:45:40pm
Hmm, genuine gasket and the o ring was new and held in place with grease as I always do - I doubt it isn't in there.
1st Sep, 2014 at 08:22:55pm
It's not the oil pickup pipe gasket or something is it? Don't think that's been mentioned yet. On 26th Jan, 2012 Tom Fenton said:
1st Sep, 2014 at 09:30:37pm
usually what happens here is where the O ring sits on the gearbox the gasket covers the O ring and never seals correct, causing this classic problem i have found out
2nd Sep, 2014 at 02:40:53am
+1 one with benross
2nd Sep, 2014 at 01:15:50pm
+2 trimmed the gasket when building my small bore I run a supercharger and I don't care the TB is on the wrong side.
2nd Sep, 2014 at 08:21:54pm
Missed that trick.
2nd Sep, 2014 at 09:09:47pm
the OEM gasket were trimmed the copys are NOT this is one to watch for gents as it gave me a large pain in the rear
![]() 608 Posts Member #: 1106 Post Whore Hungerford, Berks |
8th Sep, 2014 at 08:38:02am
On 1st Sep, 2014 BENROSS said:
also i have one turbo oil pump from minispares which was goosed in the past Steve what was wrong with it when you say "goosed"? I've had my engine fired up several times now since it was built and it has always had good oil pressure. My first run on boost was last Sunday (week yesterday) and when I ran it down I still had good pressure. The next time I went to start it up, this Saturday just gone, I have no pressure. I've Check the oil pressure relief valve which seemed to be seating fine, but replaced it will a ball bearing anyway. Also Primed the oil pump by pouring oil down the pipe and pushing backwards in 4th gear. I just cannot get any pressure, hence me asking the above. ’77 Clubman build thread
8th Sep, 2014 at 09:32:11pm
graham, i would replace the OEM relief valve set up. as a start.
13th Sep, 2014 at 05:16:56pm
Well, I've found black rubbery bits on the dipstick, either rubber or RTV, but feels strong enough to be rubber - guess the O ring did dislodge on assembly.....
13th Sep, 2014 at 05:59:51pm
Clean the area with thinners and super glue the seal in, also don't forget about the gasket mod above. Keep us posted
13th Sep, 2014 at 06:36:56pm
How much do you cut away? Just the OD of the O-ring or a bit more to make sure it's clear? |
13th Sep, 2014 at 08:20:09pm
just cut say around 1mm all the way around the seal on the OD enough to expose the seal so it does its job ok and a little clearence
Page: |
