Home > Show Us Yours! > Fiat cinquecento Radiator
alaskanow0
Member #: 8466
Mansfield
Any body weighed this radiator. I'm considering swapping to a front mount, to free up some power from not running the mechanical fan. I was also hoping to save some weight at the same time. My current alloy rad, cowl and fan weighs about 3.5kg
Edited by alaskanow0 on 26th Aug, 2014.
I can probably weigh a bare cinq rad for you this evening matt if that's of any help?
alaskanow0
Member #: 8466
Mansfield
Thanks, would be a big help.
You need to take water volume into the equation too matt.
alaskanow0
Member #: 8466
Mansfield
Why does it hold more water?
It quite possibly could. And there are different styles, I got stung by a shit one which would have towed to cool a 998! Also any new coolant hoses would prob be longer increasing volume still.
The bare cinq rad with no temperature switch that I have weighs 1.19kg, could save a few grams cutting off a big plastic chunk that doesn't do anything.
Tupers
Member #: 9441
South Devon
Carl is there any chance you could put up the dimensions as well?
Got a pic Carl?
I'll measure it and throw a pic up when I get back home, currently taking a faulty graphics card back to pc world after my old card crapped itself yesterday :(
The core is 2cm x 24cm x 45cm. The rad is 50mm deep including the fan feet, 60cm wide including the outlets and the foot thing on the end. Hose outlets are 32mm.
Shauna
Member #: 10424
Swansea boyo!
Send me a photo if you want and I'll post it up *tongue*
Shauna
Member #: 10424
Swansea boyo!
Here you gooooo, it's the photo from when he bought it
A bit of a thread revival. Does anyone know the thread size for the rad fan switch for these?
My radiator is missing one so need suitable plug, or just buy a switch.
ministar
Member #: 10760
Derby
M22 x1.5
Great, thanks.
