Home > Show Us Yours! > mid 70,s clubman body fabrication rebuild/strengthen ready for big power
stumpypower75
Member #: 10940
Thnks guys is there a project section ? I just replaced the Top cash rail with a custom made replacement along with the new windscreen mounting l8 and some 25mm Box section Frameworks to Beef up the bulkhead area i need to make some custom inner wings (rear halves) t this point ime wondering What engines are there That need some bulkhead mods as i Flips build It around the Motor it theres One you guys van recomend Rather than doing It [/URL[URL=http://s1049.photobucket.com/user/Charlie55/media/mini/IMAG0014_zpsa56ecf98.jpg.html][/URL[URL=http://s1049.photobucket.com/user/Charlie55/media/mini/IMAG0012_zps46c11e6c.jpg.html][/URL[URL=http://s1049.photobucket.com/user/Charlie55/media/mini/IMAG0013_zpsc3644bc6.jpg.html]
Edited by stumpypower75 on 25th Aug, 2014.
stumpypower75
Member #: 10940
I did Register before as stumpypower but löst my Log in Details ect so i have a mid 70s clubman and its a genuine rotbox but ive replaced a Bit of metal so far progress Slider than IDE have liked but family ect need some time as well replaced both door pillars and doorsteps the inner hinge panels. The Top dash rail and windscreen rubber mounting lip ime from south Wales Of Amy members around These parts. Next Job is gab a bulkhead Box and a new pair of inner wings rear half as its having a Flop front so dont need the front section so loathed to but gen inner wings at 400 quid to Chip em in half so i figure i will make em
Hi mate,
It's Called show us yours!
Maybe one of the mods can move this for you *smiley*
stumpypower75
Member #: 10940
Thanks mate...Yes please...mods if you can move this to the project section that Would be fantastic
Moved it for you. You can edit the title now if you wish to point out that its your build thread
stumpypower75
Member #: 10940
Has anyone Made their own complete rear half inner wings guys Mine are rotten and i fancy making instead of buying even if i need to Alter the shape on them slightly So their more angular than curved cheers guys Amy Links to someone thats done heavy bulkhead ans inner wing refabrication
D4VE
Member #: 10749
lowestoft suffolk
Pattern inner wings are dirt cheap but id just have ago if your up for it..
Nothing gets past Dave lol
stumpypower75
Member #: 10940
Can you get pattern complete inner wings its only the rear half sections i need ime loathed to but genuine bmh panels to Chop them in half thanks for reply buddy...ime deffo up for It and using slightly thicker steel as well agile ime at it
Edited by stumpypower75 on 26th Aug, 2014.
stumpypower75
Member #: 10940
What ggauge steel are you guys using for your repair sections my Top dash panel i used 1.6 mm i have plenty of this and want to go a Bit thicker than the Standard british leyland steel from the factory but Not By to much
I made my own, but no pics, it was 15 years ago. You only need .9mm. Its the shape that gives strength, not gauge
stumpypower75
Member #: 10940
ok cool Ive got 1.2 mm so will use that with done swage lines in it
redrat
Member #: 9107
Devon
I've been telling my wife that for years ! *happy*
stumpypower75
Member #: 10940
Yea me to lol.....*happy*
Ime Kind of haken with the idea of building my own bulkhead and Floor around a bg engine Amy ideas guys
stumpypower75
Member #: 10940
Front or rear wheel drive Been thinking along the 1.8k series route but Also like the rwd ....how i build the body from here is dictated to some extent By the engine choice 2.9 24valve ford Also sounds. good
