Home > 998cc > locking n/a distributor to suit low boost turbo engine
rob620
Member #: 10537
Hello! Right im currently in the mits of converting a 1275 a plus engine into a low boost turbo motor using the gt17 turbo. I woulx like to run around 10psi if not a little more if possible on standard 21268 pistons, as funds are tight id like to use a standard dizzy at the moment till I can afford megajolt setup, ive heard people talk about locking the dizzy at 24-25degrees? Can anyone please explain how I do this? :) ive also thought of using a metro turbo dizzy, would this be a simple change of the dizzy and fine on my set up? Thanks!
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
weld the weights so they dont move then wack it in and strobe it till your at the desired timeing
its not a good way to do it manny cheepish ways to get mapped ign
by the way better to keep just one post in the same place
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
by they way id not want to run more than like 7-10 on sdt pistons with out a good ic and maby piston cooling jets
