Home > Technical Chat > Calculating required pressure ratios and air flow
carts60
Member #: 9335
Bromley, SE London
Hi chaps,
My project is progressing nicely and I am starting to have doubts over the efficacy of the T2 I have strapped to the back of the motor.
I have started to have a sniff around and look at small capacity turbos which could suit the car but I have no idea how to actually measure the suitability in technical terms when looking at Pressure Ratio and Air Flow.
Is there a lay-man's explanation or guide to calculating an engine's requirements and matching them to an alternate turbo.
Dave
The Garrett web sight has good info
Basic http://www.turbobygarrett.com/turbobygarrett/basic
Adganced http://www.turbobygarrett.com/turbobygarre...o_tech_advanced
Expert http://www.turbobygarrett.com/turbobygarre...rbo_tech_expert
If you have a click around on the turbo tech menu there is more aswell
Edited by Brett on 29th Jul, 2014.
carts60
Member #: 9335
Bromley, SE London
Thanks Brett.
