Home > Wanted > Some nuts that you boys may have sat about
Lads I am looking for some nuts that you may have in your scrap bins.
1. Gearbox pinion nut
2. The nut on the end of the cam
3. The nut that holds the output gear (the bottom drop gear) on
Also one of each of the washers that go on the radius arm / top arm shafts, as I am sure they are different sizes.
I should be at IMM / MITP
Thanks simon.
Gavin Wakely
Member #: 793
Hi Simon
I've got all of them mate *Clapping* will bring them 2 MITP
Gavin (07967506369)
I've chucked in a cam nut retaining washer to.
Edited by Gavin Wakely on 21st Jul, 2014.
What a bloke!
Paatterns for titanium replacements no doubt
He's probably exhausted every other nut and bolt on the car haha.
Maybe *wink*
Remember as its just as easy to make 2 of something once its all set up. *wink*
If that's the case you may as well make me a gear box when you make jim's
haha walked into that one!
get your fuel lines done and a may consider it. *wink*
Why re invent the wheel?...... ^^^^ clicky linky^^^^........
Maybe *wink*
What you mean colin?
What I mean is that if these are indeed intended as patterns for titanium replacements, then all you really need to do is talk to Fast Carl.
But then, I think you have a few secret contacts that can sort you out, cos those bolts I bought from you didn't just come off the shelf either *happy*
Well Colin everyone needs there secrets lol.
In Simons case internet history :)
