Page: |
Home > Wanted > VP3C/276 cam | |||||||
3673 Posts Member #: 9300 Post Whore Quarry Bonk |
19th Jul, 2014 at 08:34:49pm
Bit of a long shot as there's not many around, but I'm after one for my temp n/a 1275 to give it some more grunt, or a kent 276 failing that.
4304 Posts Member #: 1321 Post Whore Wiltshire |
19th Jul, 2014 at 09:10:19pm
276's are a waste of time On 7th Oct, 2010 5haneJ said:
1391 Posts Member #: 1686 Post Whore Oxford |
19th Jul, 2014 at 10:01:37pm
Id say step it up a notch and throw in a 296.
Edited by Sam on 19th Jul, 2014. On 19th Feb, 2011 Miniwilliams said:
OMG Robert that's a big one |
19th Jul, 2014 at 10:23:26pm
Well I'm open to suggestions but it'll be a 1275 a+ std bore, 3.1 diff, megajolt, pre verto ultralight flywheel, and home ported/vizardised head and hif44, possibly centre main strap. Want something that will pull to around 7kish for a bit of fun, but I don't want something too compromised at low rpm. Thinking about 10.1 comp ratio too on 97ron unleaded. Edited by Carlzilla on 19th Jul, 2014. On 26th Jan, 2012 Tom Fenton said:
510 Posts Member #: 1592 Smart Guy! mainland europe near ze germans |
20th Jul, 2014 at 01:33:53pm
when in doubt undercam.
20th Jul, 2014 at 03:10:25pm
I'm only after around 90hp, nothing too up top but with a few more than standard revs to play with, After flicking through the yellow bible those two stood out to me. On 26th Jan, 2012 Tom Fenton said:
7763 Posts Member #: 74 I pick holes in everything.. Chief ancient post excavator |
20th Jul, 2014 at 10:19:49pm
On 19th Jul, 2014 Sam said:
Id say step it up a notch and throw in a 296. Had one in a 1293 with a head that kept the port sizes reasonable. Still made 118hp if my memory serves me correctly. Drove just fine with mappable ignition. I had a 286 in a 998 and that was a kitten too. Just seen what your thread title says. Serves me right for jumping in off the front page A 296 in anything but a full race build is also a waste of time. On 13th Jul, 2012 Ben H said:
21st Jul, 2014 at 07:04:33am
I don't agree but that's for another thread im sure. On 19th Feb, 2011 Miniwilliams said:
21st Jul, 2014 at 05:53:11pm
I used a 285 cam daily for 5k miles in a 1275. Compression was low too due to MT pistons. still pulled 88hp and never a drivability problem. On 7th Oct, 2010 5haneJ said:
22nd Jul, 2014 at 05:33:47am
I had the vp3c cam, great cam imo, seems to sit between 276 and 286 and was pulling around 104bhp at the fly. I would highly recommend it |
6745 Posts Member #: 828 Post Whore uranus |
22nd Jul, 2014 at 05:40:25am
276 kent with 1.5 rockers was quite astonishingly fast,with a good head, in my old 1275gt . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
22nd Jul, 2014 at 07:48:24pm
22nd Jul, 2014 at 08:42:43pm
On 21st Jul, 2014 Sam said:
I don't agree but that's for another thread im sure. If you've built a non full race engine that runs decent with a 296, you've done something wrong. Read: You've not used the potential in the camshaft= you could have got the same results with a milder cam and a decent build. Disagree as much as you like. On 13th Jul, 2012 Ben H said:
Page: |
