Page: |
Home > Technical Chat > Spark plugs and and thermostat temp | |||||||
82 Posts Member #: 9772 Advanced Member Sheffield |
10th Jul, 2014 at 02:56:50pm
Hi Guys, can anyone advise me on what rating/type of spark plugs and also the recommended thermostat temperature I should be running with the following spec.
510 Posts Member #: 1592 Smart Guy! mainland europe near ze germans |
10th Jul, 2014 at 04:11:38pm
As for plug heatrange . and to be honest I only recently found out what the heck the heat range does, it depends on usage.
Edited by Sir Yun on 10th Jul, 2014. That sir, is not rust, it is the progressive mass reduction system
9502 Posts Member #: 1023 Post Whore Doncaster, South Yorkshire |
10th Jul, 2014 at 06:10:55pm
What boost? I would probably go with Ngk bpr6es they did fine for me 20psi no problem I think my water injection kicked in around 15psi and when this was on it allowed boost upto (and over) 25psi
Yes i moved to the darkside
10th Jul, 2014 at 08:18:30pm
Thanks for the info and forgot to state the car will be for road use only and dependant on rolling road figures when finally ready for the road I'm guessing will probably run between 12-14psi boost. |
13th Jul, 2014 at 09:03:09pm
So no any thoughts on the thermostat temp or is that dependant on the spark plugs? |
Page: |
