Page: |
Home > Technical Chat > RTS verto - another question / thoughts | |||||||
8th Jul, 2014 at 10:21:15am
I dismantled three yesterday evening, two OEM APs and one aftermarket QH (not sure whether they were trying to copy AP or Valeo but it's key dimensions certainly aren't AP).
Edited by Rod S on 8th Jul, 2014. Schrödinger's cat - so which one am I ??? |
10021 Posts Member #: 1456 Mongo Barnsley, South Flatcapshire |
8th Jul, 2014 at 10:51:44am
Light blue is turbo I think. If something is worth doing, it's worth doing half of. |
9502 Posts Member #: 1023 Post Whore Doncaster, South Yorkshire |
8th Jul, 2014 at 11:42:31am
I attempted to add more straps but couldnt get any the same length mine was the 4th or 5th rts I built so had many spares but still non right length in time I ended up bolting the ones I took off back on and running with the origional 2 on the 3 locations Yes i moved to the darkside
11046 Posts Member #: 965 Post Whore Preston On The Brook |
8th Jul, 2014 at 01:34:03pm
The new minispares and med uprated AP clutch has a minimum of four straps on each as standard. Those are colour coded light green.edit.... Or is it dark geen. Poop i cant remember. Edited by Sprocket on 8th Jul, 2014. On 26th Oct, 2004 TurboDave16v said:
8297 Posts Member #: 408 Turbo Love Palace Fool Aylesbury |
8th Jul, 2014 at 06:24:16pm
I put 4 straps on mine in the end, and just made some new rivets up to replace the original ones. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
9th Jul, 2014 at 09:56:15am
Thanks all,
9th Jul, 2014 at 07:17:38pm
For the weight watchers,
536 Posts Member #: 5449 Post Whore Melton Mowbray |
10th Jul, 2014 at 04:40:41pm
Rod, you haven't got a spare set of ap centre hub bolts have you please? It's about all that's holding me back to get the engine in now :(
cool, i'll pop over with my tool and some lube, lol 1293 88.8hp 82.2ftlb 17.3 1/4 @ 78 mph Naturally Aspirated (for now) |
11th Jul, 2014 at 08:22:23am
Hi James,
11th Jul, 2014 at 05:41:58pm
Hi Rod, thanks for the heads up! Like you, I'd like new ideally too, being an important part of the engine build. There is a couple of fixings places near me I can try, it's just getting there in their working hours which is the problem. I'll see if any are open in the morning as I'm off. If I find anything suitable would you like me to get an extra set and post them to you? On 25th Sep, 2009 mini13 said:
1030 Posts Member #: 1291 Post Whore Suffolk / Birmingham |
11th Jul, 2014 at 06:43:18pm
Page: |
