Home > A-Series EFI / Injection > Ms sparks when switched in
Arnoud
Member #: 1085
Netherlands
Actually it's a kdfi but to all intends and purposes it's an MS. when I switch it on it sparks two plugs. On a carburetted engine which has stopped running only shortly before this results in quite an explosion which seems undesirable. Any way to make it not do that?
Thanks as always:)
Arnoud
1963 Cooper
1975 Pick Up
This sounds like a good thread to read.
http://www.miataturbo.net/megasquirt-18/be...-circuit-33964/
This comes up time and time again on the MS-E forums.
Whilst the Miata article is technically correct as to the cause (CPU pins being high during boot up or re-flash) it simply isn't necissary to re-design the electronics - just follow the external wiring diagram correctly with respect to the fuel pump relay, main relay and coil (and injectors in most MS-E cases).
If followed correctly, the coil(s) cannot be charged until the CPU has booted and, once booted, not until the CPU instructs them to.
It may be that because you are on a carb you haven't appreciated the significance of the wiring or maybe kdfi forgot to "borrow" that part of the diagram.
EDIT - typo
Edited by Rod S on 3rd Jul, 2014.
