Page: |
Home > Technical Chat > Valve Spring Removal | |||||||
1425 Posts Member #: 9199 Post Whore Lancashire |
17th Jun, 2014 at 11:31:50am
Looks like the mini has found another issue to throw at me........
1030 Posts Member #: 1291 Post Whore Suffolk / Birmingham |
17th Jun, 2014 at 11:47:15am
You can do it. You put compressed air down your plug hole and make some kind of lever setup from the rocker post/head stud to compress the spring. Not sure its worth fannying about with if you dont have the kit already tho. |
5417 Posts Member #: 6181 Double hard bastard brookwood woking |
17th Jun, 2014 at 11:57:12am
Head off time mate I have started posting on Instagram also my name on there is turbomk1golf
17th Jun, 2014 at 12:01:14pm
I will not be defeated, that head is not coming off just yet.
On 17th Jun, 2014 madmk1 said:
Head off time mate What the mind can conceive the mini can achieve
17th Jun, 2014 at 12:07:24pm
Yes mate I have loads sat about, what I would say mate is make sure you CR is right is that's where all my sadness came from. I have started posting on Instagram also my name on there is turbomk1golf
10021 Posts Member #: 1456 Mongo Barnsley, South Flatcapshire |
17th Jun, 2014 at 12:10:34pm
Do you have inner spring locators? If something is worth doing, it's worth doing half of. |
17th Jun, 2014 at 12:28:00pm
Not sure, its a Benross head.
On 17th Jun, 2014 John said:
Do you have inner spring locators? What the mind can conceive the mini can achieve
17th Jun, 2014 at 12:38:54pm
Ask Steve about it. If it hasn't it may be worth adding them and glueing the seal down as well. If something is worth doing, it's worth doing half of. |
1434 Posts Member #: 8466 Post Whore Mansfield |
17th Jun, 2014 at 02:36:47pm
Just glued one of mine in situ. Easier though, as I am only running single springs. Class C 3rd Place Avon 2011 14.18 @101mph |
Site Admin 15300 Posts Member #: 337 Fearless Tom Fenton, Avon Park 2007 & 2008 class D winner & TM legend. |
17th Jun, 2014 at 02:44:58pm
You can do the spring in situ by feeding soft rope through the spark plug hole then winding the piston to TDC which will hold the valve up.
17th Jun, 2014 at 02:50:28pm
How would you compress the valve spring using this method mate? If something is worth doing, it's worth doing half of. |
17th Jun, 2014 at 02:51:46pm
On 17th Jun, 2014 Tom Fenton said:
You can do the spring in situ by feeding soft rope through the spark plug hole then winding the piston to TDC which will hold the valve up. What the mind can conceive the mini can achieve
17th Jun, 2014 at 02:59:05pm
You'd need something that hooks under the rocker shaft with a long lever to allow you to pull the spring down.
17th Jun, 2014 at 03:01:57pm
Something like this
17th Jun, 2014 at 04:29:52pm
http://www.ebay.co.uk/itm/Sealey-VS1601-co...=item2a3e02a261
Something like this http://www.ebay.co.uk/itm/SEALEY-TOOLS-VS1...d#ht_1884wt_818 What the mind can conceive the mini can achieve
16540 Posts Member #: 4241 King Gaycharger, butt plug dealer, Sheldon Cooper and a BAC but generally a niceish fella if you dont mind a northerner Rotherham, South Yorkshire |
18th Jun, 2014 at 05:37:14am
Headgasket is cheaper... On 11th Feb, 2015 robert said:
i tried putting soap on it , and heating it to brown , then slathered my new lube on it |
18th Jun, 2014 at 06:51:26am
Tight arse lol.
On 18th Jun, 2014 apbellamy said:
Headgasket is cheaper... What the mind can conceive the mini can achieve
18th Jun, 2014 at 08:02:40am
Do em with oil if you have run out. I'll have a look if I still have a packet as I use a large tube usually. If something is worth doing, it's worth doing half of. |
18th Jun, 2014 at 11:39:26am
On 18th Jun, 2014 John said:
Do em with oil if you have run out. I'll have a look if I still have a packet as I use a large tube usually. What the mind can conceive the mini can achieve
270 Posts Member #: 69 Senior Member Coventry |
18th Jun, 2014 at 12:07:42pm
I have a special tool like the once suggested, grips around bottomcoil of spring and then leavers down on cap, the good length of about 4mm Diameter nylon cord in the bore when piston about 3/4 of way up and then turn engine over by hand to crush it into the chamber to hold valve in place, this works better than the compressed air tool, I have one of those as well. Used to do this all the time on the old Sierra CVH engines. |
3588 Posts Member #: 655 Post Whore Northern Ireland |
18th Jun, 2014 at 02:59:40pm
Yup, rope method is a doddle, and more trustworthy than air.
Page: |
