Home > Wanted > Front damper spacers
After the metal tubes/sleeves/spacers as fitted behind the front damper on both the top arm pin. If nobody has any lying around I'd be happy to pay someone to make me some from steel/ally. Don't have any measurements though as I don't have one, they've disappeared haha.
Thanks in advance!
Edited by Carlzilla on 8th Jun, 2014.
lee.pb
Member #: 9199
Lancashire
http://www.minispares.com/catalogues/class...s.aspx?2~15~132
http://www.minispares.com/product/Classic/...classic/spacers damper.aspx|Back to search
On 2nd Jun, 2014 Carlzilla said:
After the metal tubes/sleeves/spacers as fitted behind the front damper on both the top arm pin and the top damper mount. If nobody has any lying around I'd be happy to pay someone to make me some from steel/ally. Don't have any measurements though as I don't have one, they've disappeared haha.
Thanks in advance!
What on earth, went into minispares yesterday and they didn't sell them separately? :S
Also, is there commonly a spacer fitted to the top damper bracket? Sure I pulled one off before. I have new gen top arms so are the spacers built in to those?
Tried minispares, they didn't have any top arm damper spacers in stock :/
