Home > For Sale > Ultralight Pre-Verto Clutch setup and Hi-Torque Inertia Starter
All items below are zero miles and around 1 hours running time. I'm going RTS, so it's all surplus to requirements. All you need is a friction plate and it is good to go.
Hi Torque Inertia Starter - Reconditioned Lucas starter with an adaptor plate to fit the mini. Made by a Friend of Wil H. Requires the bottom bolt hole in the transfer case to be drilled out. £100 + £10 P&P
Minispares Ultralight Flywheel as per - www.minispares.com/product/Classic/Clutch/Flywheel/C-AEG620.aspx £110 + £10 P&P - Strap spacers in the pic below
Grey Cover - £25 + £6 P&P as per www.minispares.com/product/Classic/Clutch/Performance/C-AEG482.aspx
MED HD Clutch Arm and plunger, 6 x MED Competition Drive Straps, 2 x standard straps, MED Flywheel Bolt (standard washer), New release bearing and MED EN16T Drive Strap Bolts.
http://www.med-engineering.co.uk/catalogue...d-hd-clutch-arm
http://www.med-engineering.co.uk/catalogue...on-drive-straps
http://www.med-engineering.co.uk/catalogue...bolt-and-washer
http://www.med-engineering.co.uk/catalogue...ive-strap-bolts
Cost close to £150. Asking £100 + £6 P&P
Aluminium Back Plate - Rear has corroded and I'm not convinced it's 100% flat - £30 plus £10 P&P SOLD AS SEEN.
Edited by apbellamy on 31st May, 2014.
I'll definitely have the clutch arm and PM sent.
Phil.
graemec
Member #: 1424
Carnforth, Lancs
I'll take the starter.
Can we combine postage Phil?
Phil has asked about possibly having most of the items, including the starter Graeme, I'll PM you if he doesn't want it and update the thread. This is the starter fitted (loads of clearance for a rad/intercooler):
graemec
Member #: 1424
Carnforth, Lancs
Fairy nuff - not something I desperately need.
All provisionally sold bar the Grey Diaphragm.
I'll have the grey cover kid.
Smashing. You calling in for it?
will do, but know not when,
Edited by fastcarl on 1st Jun, 2014.
I need to entertain Leo on Saturday morning, so I might pop up to you for a brew.
