Page: |
Home > A-Series EFI / Injection > My 1998 SPI AUTO Gear Mini cooper MS 2 Project | |||||||
6 Posts Member #: 10848 Junior Member |
27th May, 2014 at 10:34:41am
27th May, 2014 at 10:50:43am
Have a read of this build guide:
27th May, 2014 at 10:56:12am
Also, you may have one of those hybrid Spi/Mpi engines. SPi engines were not fitted with coil packs in the UK, but I vaguely remember someone saying that there were some exceptions.
11046 Posts Member #: 965 Post Whore Preston On The Brook |
27th May, 2014 at 12:09:49pm
The 'MPi' auto was only available in Japan and actually used the SPi injection manifold specifically for the auto box kickdown mechanism.
Edited by Sprocket on 27th May, 2014. On 26th Oct, 2004 TurboDave16v said:
27th May, 2014 at 04:17:49pm
So there may be a MPi cam fitted. Check lobe behind blanking plate.
27th May, 2014 at 05:58:05pm
The 'MPi' auto block doesn't have the cam sensor hole drilled, it's as cast.
27th May, 2014 at 06:34:33pm
On 27th May, 2014 Sprocket said:
Not sure introducing all these extra complexities will yeild any worthwhile benefit over the SPi manifold. Seems like a lot of work for little gain. I remain skeptical. By all means install the MS2/3, you will certainly see some improvements there and open up cam choice. In this case, I would agree. The starting point of a SPi auto creates a lot of hurdles to overcome. Fitting the MS3 and MPi manifold to my lads 998 was a breeze, but then I've done that sort of thing before and I'm biased Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
5 Posts Member #: 10833 Junior Member |
28th May, 2014 at 03:45:41pm
Dear Paul. I am in srilanka, Recently visited UK Birmingham.crazy about cars. I really want to make this happen. Jean told me he can send the VR conditioning circuit for cam sensor, I am going to drill the cast , exact point of the engine block , I am doubt , I got a same MPI cam in my car. then i dont need a cam replacement.I got down this car from japan, I am really curious about to know about fixing wideband 02 sensor too, cause jean told me I might need 2 or three wide band o2 sensors, can you explain why i need many of them>? why I cannot use existing o2 sensor (Is it a narrow band one?)
28th May, 2014 at 03:48:19pm
oops. sorry I saw the link lately. I will go through them and comeback with some photographs |
28th May, 2014 at 03:56:28pm
You will need 2 widebands to understand the fuel distribution between inner and outer cylinders and make adjustments to the injector timing.
28th May, 2014 at 04:13:34pm
according to your advice I might need to order injector drive board and cam sensor input modification board from jean? what about o2 sensors? since i am in srilanka i can find o2 sensors from very modern Japanese toyota or nissans made in 2004 upwors, Can you give a clue to find o2 sensors from those cars?? Are they really wideband??
28th May, 2014 at 04:27:03pm
No, you don't need the quad driver board from Jean. You can drive the 2 MPi injectors and the wasted spark coil without.
28th May, 2014 at 06:24:09pm
So I will fix the cam ASAS. huraah. If I dont need the quad driver board , how can i run fully sequential injection. Can it be done only by two injectors??? please correct me if I am wrong. since i got only two injector outputs how its serve 4 cylinders. In original MEMS MPI ecu I saw 2 Injector out puts given to one injector and other two output given to the other injecter. that means origial rover ECU got 4 injector outputs while i am having two outputs only on my MS2.???
28th May, 2014 at 07:22:58pm
This is not an easy project but it is something that can be done if you put the effort in understanding what is needed. You need to start reading and be ready to read a lot.
28th May, 2014 at 08:51:18pm
On 28th May, 2014 priyanga said:
So I will fix the cam ASAS. huraah. If I dont need the quad driver board , how can i run fully sequential injection. Can it be done only by two injectors??? please correct me if I am wrong. since i got only two injector outputs how its serve 4 cylinders. In original MEMS MPI ecu I saw 2 Injector out puts given to one injector and other two output given to the other injecter. that means origial rover ECU got 4 injector outputs while i am having two outputs only on my MS2.??? And I am little bit fancy of having to put 4 wire cops instead of having wasted spark coil pack. because I can buy used cops ( Japanese ) cops in my country. can you tell me can I put 4 wire 4 cops to my mini without having jeans support?? As already said by Paul, Jean and Colin (Sprocket) this isn't easy with the rather strange engine you have but it is possible if you really want to do it. To answer your latest questions in detail.... You only need two injector drivers with the MS2-E siamese code because it fires the two injectors twice at defined crank angles so replicating the normal four injectors you would expect on a normal 8 valve fully sequential engine. Rover doubled the four outputs from their MEMS to two injectors because they had a 4 channel MEMS from their other ranges but had to work with two injectors. The MS2-E siamese code does the same with two drivers except it does it better (well IMO anyway). You only need Jean's 4 channel driver board if you are in the really serious territory of staged injection (usually only with a turbo) and then you need some modifications to the MS2 daughterboard as well. The standard MS2 build is fine for fully sequential siamese code. For any form of sequential you need the cam (phase) input. If you have an MPI cam and drill the rather strange block to take it, you will need some additional input circuitry, as already mentioned. We can explain more later once you accept the basic problems. The MS2 will drive a wasted spark coilpack but you will have to modify it to include a second IGBT (ignitor) or use a logic driven coilpack. Again, more details later. If you want COP, it gets more complicated, again, depending if they are logic level of IGBT driven. All still doeable but you need to understand the basics first. Another thing you need to consider as this seems to be a rather strange engine, is the fuel pump inside the tank an MPI one or an SPI one ? The SPI one won't be any good for normal injectors as normal injector require 3 bar, the SPI only ran at 1bar. And to answer one of your earlier questions you absolutely need two widebands (and associated controllers) to setup the fuelling if you go the way of siamese code port injection. Edited by Rod S on 28th May, 2014. Schrödinger's cat - so which one am I ??? |
774 Posts Member #: 6724 Post Whore Wootton Bassett |
28th May, 2014 at 08:51:30pm
as above, also try these...
28th May, 2014 at 09:19:55pm
Interesting. I had never seen that first link. |
28th May, 2014 at 09:49:33pm
The 1998 automatic engines were only available in the japanese market. The block was a modified 'MPi' block and head, but the induction system was the SPi injection manifold and air cleaner. This allowed the automatic gearbox kickdown linkage to be connected with an already available mechanism.
29th May, 2014 at 08:49:37am
On 28th May, 2014 jbelanger said:
Interesting. I had never seen that first link. Me neither. I'm guessing that's from "alpa": http://www.turbominis.co.uk/forums/index.php?p=vt&tid=364031 Interesting write up although has got the charge stealing issue incorrect. EDIT: Missed the links that take you straight to this forum and alpas threads - Doh. Edited by Paul S on 29th May, 2014. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
29th May, 2014 at 09:10:38am
On 28th May, 2014 Sprocket said:
Suggestions for a work around for the kickdown linkage?...... How about: Adapting the linkage to the free end of the throttle body, or Doubling up the throttle cable, or Vacuum diaphragm actuator from a R5GTT? Do-able with a bit of ingenuity and fabrication, not impossible. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
29th May, 2014 at 10:33:14am
Dear Friends. I really did understand up to some extend and decided to buy an complete engine to keep separately and do my trials, My only problem now is to find Wide band 02 sensors. so i need to try ebay to get them down. I will keep update the forum, its look like not easy as i thought. lets hope for the best. |
16th Mar, 2015 at 01:57:51pm
Dear Friends
16th Mar, 2015 at 02:23:13pm
Use the 5V version and put it inside the MS2 case.
Page: |
