Page: |
Home > Technical Chat > GT17 Shaft play | |||||||
1425 Posts Member #: 9199 Post Whore Lancashire |
16th May, 2014 at 07:17:37am
Since i've stripped the top end down to replace the damaged head gasket, i've noticed some slight play in the turbo.
537 Posts Member #: 8926 Post Whore Sheffield |
16th May, 2014 at 07:48:41am
Did you replace the everything except the shaft? my turbine shaft looked a little worn so if mine starts to play up i know it will pretty much be the cause of it. |
16th May, 2014 at 07:56:53am
Yep used everything in the kit that would fit my turbo.
16th May, 2014 at 07:59:11am
I think you are in the same boat as me with it then mate. I would wait until it gets smokey haha |
16th May, 2014 at 08:11:24am
the only issue i have is that i've have the actuator is welded on to the intake chamber so dont fancy damaging it, if the play gets really bad.
On 16th May, 2014 Nick warwick said:
I think you are in the same boat as me with it then mate. I would wait until it gets smokey haha Edited by lee.pb on 16th May, 2014. What the mind can conceive the mini can achieve
1750 Posts Member #: 10190 Post Whore belgium |
16th May, 2014 at 06:16:30pm
How much play may there actually be in a gt 1752? you can do anything if you set your mind to it...
17th May, 2014 at 08:14:33am
i'll get a video, but had a price of £190 for a new core tohough. What the mind can conceive the mini can achieve
9502 Posts Member #: 1023 Post Whore Doncaster, South Yorkshire |
17th May, 2014 at 08:43:31am
How close to the compressor housing does the turbine wheels come? As long as it doesnt touch whilst dry from oil its not going to touch while its at oil pressure you would be surprised how much difference it makes
Yes i moved to the darkside
17th May, 2014 at 11:31:35am
It oges no where near brett, rotated the shaft with a little pressure on the shaft and it doesnt touch.
On 17th May, 2014 Brett said:
How close to the compressor housing does the turbine wheels come? As long as it doesnt touch whilst dry from oil its not going to touch while its at oil pressure you would be surprised how much difference it makes What the mind can conceive the mini can achieve
17th May, 2014 at 05:40:11pm
Got 0.004" clearance with the compressor pushed towards the housing. What the mind can conceive the mini can achieve
Page: |
