Page: |
Home > A-Series EFI / Injection > Mini with Suzuki swift engine, injection problem. | |||||||
902 Posts Member #: 111 Post Whore Loughborough |
13th May, 2014 at 07:53:59am
Hi Guys,
11046 Posts Member #: 965 Post Whore Preston On The Brook |
13th May, 2014 at 09:20:59am
Far far to much advance in there at those reves and high load.
13th May, 2014 at 10:52:12am
13th May, 2014 at 01:29:17pm
What's you rev limit set to ? The map is only up to 6K so anything beyond that will flatline.
13th May, 2014 at 03:03:03pm
Rev limit is set at 7000 hard limit.
13th May, 2014 at 03:07:31pm
You say you are using the stock injection system. What does that consist of? ITBs, Plenum ?? Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
13th May, 2014 at 06:18:26pm
What were you using for ignition when you were running carbs?
13th May, 2014 at 07:13:25pm
Injection system: Plenum chamber, original injectors and fuel rail, MPI fuel pump, Ford coil pack, 36-1 trigger wheel.
13th May, 2014 at 07:37:09pm
I would suggest you post your msq and msl on the MS-E forum.
3673 Posts Member #: 9300 Post Whore Quarry Bonk |
13th May, 2014 at 09:24:39pm
I'm no expert, but I would have thought that if you ran the same ignition map as you were on carbs, and you had no problems with the carbs, then the problem lies with the fuelling? On 26th Jan, 2012 Tom Fenton said:
Page: |
